SketchAPI_MacroEllipse Class Reference
Interface for Ellipse feature. More...
#include <SketchAPI_MacroEllipse.h>
Inheritance diagram for SketchAPI_MacroEllipse:
 SketchAPI_MacroEllipse (const std::shared_ptr< ModelAPI_Feature > &theFeature, bool callInitialize=true)
 SketchAPI_MacroEllipse (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theX1, double theY1, double theX2, double theY2, double theX3, double theY3, bool byCenter=true)
 SketchAPI_MacroEllipse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint1, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint2, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint3, bool byCenter=true)
 SketchAPI_MacroEllipse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint1, const ModelHighAPI_RefAttr &thePoint1Ref, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint2, const ModelHighAPI_RefAttr &thePoint2Ref, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint3, const ModelHighAPI_RefAttr &thePoint3Ref, bool byCenter=true)
 Constructor with values and/or references. More...
virtual ~SketchAPI_MacroEllipse ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeString > ellipseType () const
 Ellipse type. More...
std::shared_ptr< SketchAPI_Point > center ()
 Return created auxiliary center point. More...
std::shared_ptr< SketchAPI_Point > focus1 ()
 Return created auxiliary focus in the positive direction of major axis. More...
std::shared_ptr< SketchAPI_Point > focus2 ()
 Return created auxiliary focus in the negative direction of major axis. More...
std::shared_ptr< SketchAPI_Point > majorAxisStart ()
 Return created auxiliary point - start of major axis. More...
std::shared_ptr< SketchAPI_Point > majorAxisEnd ()
 Return created auxiliary point - end of major axis. More...
std::shared_ptr< SketchAPI_Point > minorAxisStart ()
 Return created auxiliary point - start of minor axis. More...
std::shared_ptr< SketchAPI_Point > minorAxisEnd ()
 Return created auxiliary point - end of minor axis. More...
std::shared_ptr< SketchAPI_Line > majorAxis ()
 Return created auxiliary major axis. More...
std::shared_ptr< SketchAPI_Line > minorAxis ()
 Return created auxiliary minor axis. More...
std::shared_ptr< ModelAPI_AttributeBoolean > auxiliary () const
 Auxiliary. More...
void setAuxiliary (bool theAuxiliary)
 Set auxiliary. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
static std::list< std::shared_ptr< SketchAPI_SketchEntity > > wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures)
 Convert list of features to list of appropriate wrappers. More...
bool initialize ()
void storeSketch (const std::shared_ptr< ModelAPI_Feature > &theFeature)
bool isCopy () const
 Check the entity is a copy of another feature. More...
std::shared_ptr< ModelAPI_AttributeString > myellipseType
std::shared_ptr< ModelAPI_AttributeBoolean > myAuxiliary
◆ SketchAPI_MacroEllipse() [1/4]
SketchAPI_MacroEllipse::SketchAPI_MacroEllipse ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
bool  callInitialize = true
explicit
◆ SketchAPI_MacroEllipse() [2/4]
double  theX1,
double  theY1,
double  theX2,
double  theY2,
double  theX3,
double  theY3,
bool  byCenter = true
◆ SketchAPI_MacroEllipse() [3/4]
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint1,
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint2,
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint3,
◆ SketchAPI_MacroEllipse() [4/4]
const ModelHighAPI_RefAttr &  thePoint1Ref,
const ModelHighAPI_RefAttr &  thePoint2Ref,
const ModelHighAPI_RefAttr &  thePoint3Ref,
◆ ~SketchAPI_MacroEllipse()
SketchAPI_MacroEllipse::~SketchAPI_MacroEllipse ( )
◆ ellipseType()
virtual std::shared_ptr< ModelAPI_AttributeString > SketchAPI_MacroEllipse::ellipseType ( ) const
Ellipse type.
◆ center()
std::shared_ptr< SketchAPI_Point > SketchAPI_MacroEllipse::center ( )
◆ focus1()
std::shared_ptr< SketchAPI_Point > SketchAPI_MacroEllipse::focus1 ( )
◆ focus2()
std::shared_ptr< SketchAPI_Point > SketchAPI_MacroEllipse::focus2 ( )
◆ majorAxisStart()
std::shared_ptr< SketchAPI_Point > SketchAPI_MacroEllipse::majorAxisStart ( )
◆ majorAxisEnd()
std::shared_ptr< SketchAPI_Point > SketchAPI_MacroEllipse::majorAxisEnd ( )
◆ minorAxisStart()
std::shared_ptr< SketchAPI_Point > SketchAPI_MacroEllipse::minorAxisStart ( )
◆ minorAxisEnd()
std::shared_ptr< SketchAPI_Point > SketchAPI_MacroEllipse::minorAxisEnd ( )
◆ majorAxis()
std::shared_ptr< SketchAPI_Line > SketchAPI_MacroEllipse::majorAxis ( )
◆ minorAxis()
std::shared_ptr< SketchAPI_Line > SketchAPI_MacroEllipse::minorAxis ( )
◆ auxiliary()
std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_SketchEntity::auxiliary ( ) const
Auxiliary.
◆ setAuxiliary()
void SketchAPI_SketchEntity::setAuxiliary ( bool  theAuxiliary)
Set auxiliary.
◆ dump()
void SketchAPI_SketchEntity::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ wrap()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_SketchEntity::wrap ( const std::list< std::shared_ptr< ModelAPI_Feature > > &  theFeatures)
◆ isCopy()
bool SketchAPI_SketchEntity::isCopy ( ) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
