Interface for Elliptic Arc feature. More...
#include <SketchAPI_MacroEllipticArc.h>
| SketchAPI_MacroEllipticArc (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| SketchAPI_MacroEllipticArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const ModelHighAPI_RefAttr &theCenterRef, const std::shared_ptr< GeomAPI_Pnt2d > &theMajorAxisPoint, const ModelHighAPI_RefAttr &theMajorAxisPointRef, const std::shared_ptr< GeomAPI_Pnt2d > &theArcStart, const ModelHighAPI_RefAttr &theArcStartRef, const std::shared_ptr< GeomAPI_Pnt2d > &theArcEnd, const ModelHighAPI_RefAttr &theArcEndRef, const bool theReversed) | |
| Constructor with values and/or references. More... | |
| virtual | ~SketchAPI_MacroEllipticArc () |
| Destructor. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | startPoint () const |
| Start point of elliptic arc. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | endPoint () const |
| End point of elliptic arc. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | reversed () const |
| Reversed flag for elliptic arc. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeString > | ellipseType () const |
| Ellipse type. More... | |
| std::shared_ptr< SketchAPI_Point > | center () |
| Return created auxiliary center point. More... | |
| std::shared_ptr< SketchAPI_Point > | focus1 () |
| Return created auxiliary focus in the positive direction of major axis. More... | |
| std::shared_ptr< SketchAPI_Point > | focus2 () |
| Return created auxiliary focus in the negative direction of major axis. More... | |
| std::shared_ptr< SketchAPI_Point > | majorAxisStart () |
| Return created auxiliary point - start of major axis. More... | |
| std::shared_ptr< SketchAPI_Point > | majorAxisEnd () |
| Return created auxiliary point - end of major axis. More... | |
| std::shared_ptr< SketchAPI_Point > | minorAxisStart () |
| Return created auxiliary point - start of minor axis. More... | |
| std::shared_ptr< SketchAPI_Point > | minorAxisEnd () |
| Return created auxiliary point - end of minor axis. More... | |
| std::shared_ptr< SketchAPI_Line > | majorAxis () |
| Return created auxiliary major axis. More... | |
| std::shared_ptr< SketchAPI_Line > | minorAxis () |
| Return created auxiliary minor axis. More... | |
| std::shared_ptr< ModelAPI_AttributeBoolean > | auxiliary () const |
| Auxiliary. More... | |
| void | setAuxiliary (bool theAuxiliary) |
| Set auxiliary. More... | |
| static std::list< std::shared_ptr< SketchAPI_SketchEntity > > | wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures) |
| Convert list of features to list of appropriate wrappers. More... | |
| bool | initialize () |
| void | storeSketch (const std::shared_ptr< ModelAPI_Feature > &theFeature) |
| bool | isCopy () const |
| Check the entity is a copy of another feature. More... | |
Protected Attributes | |
| std::shared_ptr< GeomDataAPI_Point2D > | mystartPoint |
| std::shared_ptr< GeomDataAPI_Point2D > | myendPoint |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myreversed |
| std::shared_ptr< ModelAPI_AttributeString > | myellipseType |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myAuxiliary |
explicit |
| SketchAPI_MacroEllipticArc::SketchAPI_MacroEllipticArc | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| const std::shared_ptr< GeomAPI_Pnt2d > & | theCenter, | ||
| const ModelHighAPI_RefAttr & | theCenterRef, | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | theMajorAxisPoint, | ||
| const ModelHighAPI_RefAttr & | theMajorAxisPointRef, | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | theArcStart, | ||
| const ModelHighAPI_RefAttr & | theArcStartRef, | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | theArcEnd, | ||
| const ModelHighAPI_RefAttr & | theArcEndRef, | ||
| const bool | theReversed | ||
inlinevirtual |
Reimplemented from SketchAPI_MacroEllipse.
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtualinherited |
Ellipse type.
Auxiliary.
Set auxiliary.
Reimplemented in SketchAPI_Arc, SketchAPI_BSpline, SketchAPI_Circle, SketchAPI_Ellipse, SketchAPI_EllipticArc, SketchAPI_IntersectionPoint, SketchAPI_Line, SketchAPI_Point, and SketchAPI_Projection.
staticinherited |
protectedinherited |
