GeomAlgoAPI_ThroughAll Class Reference
Cuts a prism by all given objects, throw away end pieces. More...
#include <GeomAlgoAPI_ThroughAll.h>
Inheritance diagram for GeomAlgoAPI_ThroughAll:
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_ThroughAll (std::shared_ptr< GeomAlgoAPI_Prism > thePrismAlgo, const ListOfShape &theObjects)
 Redefinition of the generic method for the Fuse problem: OCCT 30481. More...
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_ThroughAll()
GeomAlgoAPI_ThroughAll::GeomAlgoAPI_ThroughAll ( std::shared_ptr< GeomAlgoAPI_Prism >  thePrismAlgo,
const ListOfShape &  theObjects
◆ modified()
void GeomAlgoAPI_Boolean::modified ( const GeomShapePtr  theOldShape,
ListOfShape &  theNewShapes
make arguments of Fuse produce result shapes with "modified" evolution
◆ build()
inlinevirtualinherited
◆ initialize()
template<class T >
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
[in]theOldShapebase shape.
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
