SketchAPI_MacroArc Class Reference
Interface for Arc feature. More...
#include <SketchAPI_MacroArc.h>
Inheritance diagram for SketchAPI_MacroArc:
 SketchAPI_MacroArc (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_MacroArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theCenterX, double theCenterY, double theStartX, double theStartY, double theEndX, double theEndY, bool theInversed)
 SketchAPI_MacroArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Pnt2d > &theStart, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, bool theInversed)
 SketchAPI_MacroArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theStartX, double theStartY, double theEndX, double theEndY, double thePassedX, double thePassedY)
 SketchAPI_MacroArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theStart, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, const std::shared_ptr< GeomAPI_Pnt2d > &thePassed)
 SketchAPI_MacroArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_RefAttr &theTangentPoint, double theEndX, double theEndY, bool theInversed)
 SketchAPI_MacroArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_RefAttr &theTangentPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, bool theInversed)
virtual ~SketchAPI_MacroArc ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeString > arcType () const
 Arc type. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > center () const
 Center point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > startPoint1 () const
 Start point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > endPoint1 () const
 End point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > startPoint2 () const
virtual std::shared_ptr< GeomDataAPI_Point2D > endPoint2 () const
 End point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > passedPoint () const
 Passed point. More...
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > tangentPoint () const
 Tangent point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > endPoint3 () const
 End point. More...
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > transversalPoint () const
 Transversal point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > endPoint4 () const
 End point. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reversed () const
 Reversed flag. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > radius () const
 Radius. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle () const
 Angle. More...
void setByCenterStartEnd (double theCenterX, double theCenterY, double theStartX, double theStartY, double theEndX, double theEndY, bool theInversed)
 Set by center and start, end point. More...
void setByCenterStartEnd (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Pnt2d > &theStart, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, bool theInversed)
void setByStartEndPassed (double theStartX, double theStartY, double theEndX, double theEndY, double thePassedX, double thePassedY)
 Set by start, end and passed points. More...
void setByStartEndPassed (const std::shared_ptr< GeomAPI_Pnt2d > &theStart, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, const std::shared_ptr< GeomAPI_Pnt2d > &thePassed)
void setByTangent (const ModelHighAPI_RefAttr &theTangentPoint, double theEndX, double theEndY, bool theInversed)
 Set by tangent and end point. More...
void setByTangent (const ModelHighAPI_RefAttr &theTangentPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, bool theInversed)
void setByTransversal (const ModelHighAPI_RefAttr &theTransversalPoint, double theEndX, double theEndY, bool theInversed)
void setByTransversal (const ModelHighAPI_RefAttr &theTransversalPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, bool theInversed)
std::shared_ptr< ModelAPI_AttributeBoolean > auxiliary () const
 Auxiliary. More...
void setAuxiliary (bool theAuxiliary)
 Set auxiliary. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
static std::list< std::shared_ptr< SketchAPI_SketchEntity > > wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures)
 Convert list of features to list of appropriate wrappers. More...
bool initialize ()
bool isCopy () const
 Check the entity is a copy of another feature. More...
std::shared_ptr< ModelAPI_AttributeString > myarcType
std::shared_ptr< GeomDataAPI_Point2D > mycenter
std::shared_ptr< GeomDataAPI_Point2D > mystartPoint1
std::shared_ptr< GeomDataAPI_Point2D > myendPoint1
std::shared_ptr< GeomDataAPI_Point2D > mystartPoint2
std::shared_ptr< GeomDataAPI_Point2D > myendPoint2
std::shared_ptr< GeomDataAPI_Point2D > mypassedPoint
std::shared_ptr< ModelAPI_AttributeRefAttr > mytangentPoint
std::shared_ptr< GeomDataAPI_Point2D > myendPoint3
std::shared_ptr< ModelAPI_AttributeRefAttr > mytransversalPoint
std::shared_ptr< GeomDataAPI_Point2D > myendPoint4
std::shared_ptr< ModelAPI_AttributeBoolean > myreversed
std::shared_ptr< ModelAPI_AttributeDouble > myradius
std::shared_ptr< ModelAPI_AttributeDouble > myangle
std::shared_ptr< ModelAPI_AttributeBoolean > myAuxiliary
◆ SketchAPI_MacroArc() [1/7]
SketchAPI_MacroArc::SketchAPI_MacroArc ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_MacroArc() [2/7]
SketchAPI_MacroArc::SketchAPI_MacroArc ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
double  theCenterX,
double  theCenterY,
double  theStartX,
double  theStartY,
double  theEndX,
double  theEndY,
bool  theInversed
◆ SketchAPI_MacroArc() [3/7]
const std::shared_ptr< GeomAPI_Pnt2d > &  theCenter,
const std::shared_ptr< GeomAPI_Pnt2d > &  theStart,
const std::shared_ptr< GeomAPI_Pnt2d > &  theEnd,
bool  theInversed
◆ SketchAPI_MacroArc() [4/7]
double  theStartX,
double  theStartY,
double  theEndX,
double  theEndY,
double  thePassedX,
double  thePassedY
◆ SketchAPI_MacroArc() [5/7]
const std::shared_ptr< GeomAPI_Pnt2d > &  thePassed
◆ SketchAPI_MacroArc() [6/7]
const ModelHighAPI_RefAttr &  theTangentPoint,
double  theEndX,
double  theEndY,
bool  theInversed
◆ SketchAPI_MacroArc() [7/7]
bool  theInversed
◆ ~SketchAPI_MacroArc()
SketchAPI_MacroArc::~SketchAPI_MacroArc ( )
◆ arcType()
virtual std::shared_ptr< ModelAPI_AttributeString > SketchAPI_MacroArc::arcType ( ) const
Arc type.
◆ center()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroArc::center ( ) const
Center point.
◆ startPoint1()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroArc::startPoint1 ( ) const
Start point.
◆ endPoint1()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroArc::endPoint1 ( ) const
End point.
◆ startPoint2()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroArc::startPoint2 ( ) const
Start point.
◆ endPoint2()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroArc::endPoint2 ( ) const
End point.
◆ passedPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroArc::passedPoint ( ) const
Passed point.
◆ tangentPoint()
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > SketchAPI_MacroArc::tangentPoint ( ) const
Tangent point.
◆ endPoint3()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroArc::endPoint3 ( ) const
End point.
◆ transversalPoint()
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > SketchAPI_MacroArc::transversalPoint ( ) const
Transversal point.
◆ endPoint4()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroArc::endPoint4 ( ) const
End point.
◆ reversed()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_MacroArc::reversed ( ) const
Reversed flag.
◆ radius()
virtual std::shared_ptr< ModelAPI_AttributeDouble > SketchAPI_MacroArc::radius ( ) const
Radius.
◆ angle()
virtual std::shared_ptr< ModelAPI_AttributeDouble > SketchAPI_MacroArc::angle ( ) const
Angle.
◆ setByCenterStartEnd() [1/2]
void SketchAPI_MacroArc::setByCenterStartEnd ( double  theCenterX,
double  theCenterY,
double  theStartX,
double  theStartY,
double  theEndX,
double  theEndY,
bool  theInversed
◆ setByCenterStartEnd() [2/2]
void SketchAPI_MacroArc::setByCenterStartEnd ( const std::shared_ptr< GeomAPI_Pnt2d > &  theCenter,
bool  theInversed
◆ setByStartEndPassed() [1/2]
void SketchAPI_MacroArc::setByStartEndPassed ( double  theStartX,
double  theStartY,
double  theEndX,
double  theEndY,
double  thePassedX,
double  thePassedY
◆ setByStartEndPassed() [2/2]
void SketchAPI_MacroArc::setByStartEndPassed ( const std::shared_ptr< GeomAPI_Pnt2d > &  theStart,
◆ setByTangent() [1/2]
void SketchAPI_MacroArc::setByTangent ( const ModelHighAPI_RefAttr &  theTangentPoint,
double  theEndX,
double  theEndY,
bool  theInversed
◆ setByTangent() [2/2]
bool  theInversed
◆ setByTransversal() [1/2]
void SketchAPI_MacroArc::setByTransversal ( const ModelHighAPI_RefAttr &  theTransversalPoint,
double  theEndX,
double  theEndY,
bool  theInversed
◆ setByTransversal() [2/2]
bool  theInversed
◆ auxiliary()
std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_SketchEntity::auxiliary ( ) const
Auxiliary.
◆ setAuxiliary()
void SketchAPI_SketchEntity::setAuxiliary ( bool  theAuxiliary)
Set auxiliary.
◆ dump()
void SketchAPI_SketchEntity::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ wrap()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_SketchEntity::wrap ( const std::list< std::shared_ptr< ModelAPI_Feature > > &  theFeatures)
◆ isCopy()
bool SketchAPI_SketchEntity::isCopy ( ) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
