Interface for Rectangle feature. More...
#include <SketchAPI_Rectangle.h>
| SketchAPI_Rectangle (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| SketchAPI_Rectangle (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theX1, double theY1, double theX2, double theY2, bool theCreateByCenterAndCorner=false) | |
| SketchAPI_Rectangle (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint1, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint2, bool theCreateByCenterAndCorner=false) | |
| virtual | ~SketchAPI_Rectangle ()=default |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeString > | type () const |
| Creation type of rectangle. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | startPoint () const |
| Start point. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | endPoint () const |
| End point. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | centerPoint () const |
| Center point. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeRefAttr > | centerPointRef () const |
| Reference to center point. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | cornerPoint () const |
| Corner point. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeRefList > | linesList () const |
| Lines list. More... | |
| void | setByCoordinates (double theX1, double theY1, double theX2, double theY2) |
| Set by coordinates. More... | |
| void | setByPoints (const std::shared_ptr< GeomAPI_Pnt2d > &theFirstPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theSecondPoint) |
| Set by points. More... | |
| void | setByCenterAndCornerCoords (double theCenterX, double theCenterY, double theCornerX, double theCornerY) |
| void | setByCenterAndCornerPoints (const std::shared_ptr< GeomAPI_Pnt2d > &theCenterPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theCornerPoint) |
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > | lines () const |
| List of lines composing rectangle. More... | |
| std::shared_ptr< SketchAPI_Point > | centerSketchPoint () const |
| std::shared_ptr< ModelAPI_AttributeBoolean > | auxiliary () const |
| Auxiliary. More... | |
| void | setAuxiliary (bool theAuxiliary) |
| Set auxiliary. More... | |
| static std::list< std::shared_ptr< SketchAPI_SketchEntity > > | wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures) |
| Convert list of features to list of appropriate wrappers. More... | |
| bool | initialize () |
| bool | isCopy () const |
| Check the entity is a copy of another feature. More... | |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeString > | mytype |
| std::shared_ptr< GeomDataAPI_Point2D > | mystartPoint |
| std::shared_ptr< GeomDataAPI_Point2D > | myendPoint |
| std::shared_ptr< GeomDataAPI_Point2D > | mycenterPoint |
| std::shared_ptr< ModelAPI_AttributeRefAttr > | mycenterPointRef |
| std::shared_ptr< GeomDataAPI_Point2D > | mycornerPoint |
| std::shared_ptr< ModelAPI_AttributeRefList > | mylinesList |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myAuxiliary |
explicit |
| SketchAPI_Rectangle::SketchAPI_Rectangle | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| double | theX1, | ||
| double | theY1, | ||
| double | theX2, | ||
| double | theY2, | ||
| bool | theCreateByCenterAndCorner = false |
| const std::shared_ptr< GeomAPI_Pnt2d > & | thePoint1, | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | thePoint2, | ||
virtualdefault |
inlinevirtual |
inlinevirtual |
Start point.
inlinevirtual |
End point.
inlinevirtual |
Center point.
inlinevirtual |
inlinevirtual |
Corner point.
inlinevirtual |
Lines list.
| void SketchAPI_Rectangle::setByCoordinates | ( | double | theX1, |
| double | theY2 | ||
Set by coordinates.
| void SketchAPI_Rectangle::setByPoints | ( | const std::shared_ptr< GeomAPI_Pnt2d > & | theFirstPoint, |
| const std::shared_ptr< GeomAPI_Pnt2d > & | theSecondPoint | ||
Set by points.
| void SketchAPI_Rectangle::setByCenterAndCornerCoords | ( | double | theCenterX, |
| double | theCenterY, | ||
| double | theCornerX, | ||
| double | theCornerY | ||
Set by coordinates.
| void SketchAPI_Rectangle::setByCenterAndCornerPoints | ( | const std::shared_ptr< GeomAPI_Pnt2d > & | theCenterPoint, |
| const std::shared_ptr< GeomAPI_Pnt2d > & | theCornerPoint | ||
Set by points.
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_Rectangle::lines | ( | ) | const |
Auxiliary.
Set auxiliary.
Reimplemented in SketchAPI_Arc, SketchAPI_BSpline, SketchAPI_Circle, SketchAPI_Ellipse, SketchAPI_EllipticArc, SketchAPI_IntersectionPoint, SketchAPI_Line, SketchAPI_Point, and SketchAPI_Projection.
staticinherited |
protectedinherited |
