GeomAlgoAPI_Defeaturing Class Reference
Perform Defeaturing algorithm. More...
#include <GeomAlgoAPI_Defeaturing.h>
Inheritance diagram for GeomAlgoAPI_Defeaturing:
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Defeaturing (const GeomShapePtr &theBaseSolid, const ListOfShape &theFacesToRemove)
 Run Defeaturing operation on the solid for the given list of faces. More...
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Defeaturing()
GeomAlgoAPI_Defeaturing::GeomAlgoAPI_Defeaturing ( const GeomShapePtr &  theBaseSolid,
const ListOfShape &  theFacesToRemove
theBaseSolida changing solid
theFacesToRemovelist of faces to be removed
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modified()
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
