GeomAlgoAPI_Filling Class Reference
Perform building face by the set of edges/wires. More...
#include <GeomAlgoAPI_Filling.h>
Inheritance diagram for GeomAlgoAPI_Filling:
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Filling (const int theMinDegree=2, const int theMaxDegree=5, const int theNbIter=0, const double theTol2D=1.e-4, const double theTol3D=1.e-4)
 Construct filling operation by the parameters. More...
GEOMALGOAPI_EXPORT void add (const GeomEdgePtr theEdge)
 Add an edge to constrain filling (the result face should pass through the edge) More...
GEOMALGOAPI_EXPORT void build (bool isApproximate=false)
 Perform filling operation. More...
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Filling()
GeomAlgoAPI_Filling::GeomAlgoAPI_Filling ( const int  theMinDegree = 2,
const int  theMaxDegree = 5,
const int  theNbIter = 0,
const double  theTol2D = 1.e-4,
const double  theTol3D = 1.e-4
◆ add()
void GeomAlgoAPI_Filling::add ( const GeomEdgePtr  theEdge)
◆ build() [1/2]
void GeomAlgoAPI_Filling::build ( bool  isApproximate = false)
isApproximateapproximate curves before building a face
◆ initialize()
template<class T >
◆ build() [2/2]
inlinevirtualinherited
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modified()
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
