Allows the elimination of coincident (duplicated) faces from a set of separate topological elements. More...
#include <GeomAlgoAPI_GlueFaces.h>
Public Types | |
| GeomAlgoAPI_GlueFaces (const ListOfShape &theShapes, const double theTolerance=1.e-7, const bool theKeepNonSolids=true) | |
| Constructor with optional arguments. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_GlueFaces::GeomAlgoAPI_GlueFaces | ( | const ListOfShape & | theShapes, |
| const double | theTolerance = 1.e-7, |
| const bool | theKeepNonSolids = true |
| [in] | theShapes | list of shapes. |
| [in] | theTolerance | tolerance to be used for gluing operation. |
| [in] | theKeepNonSolids | whether to keep non-solid shapes in the result |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
