Performs the intersection operations. More...
#include <GeomAlgoAPI_Intersection.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Intersection (const ListOfShape &theObjects, const double theFuzzy=1.e-8) |
| Constructor. More... | |
| virtual GEOMALGOAPI_EXPORT | ~GeomAlgoAPI_Intersection () |
| Destructor to erase the filler. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_Intersection::GeomAlgoAPI_Intersection | ( | const ListOfShape & | theObjects, |
| const double | theFuzzy = 1.e-8 |
| [in] | theObjects | list of objects. |
| [in] | theFuzzy | additional tolerance value. If the fuzzy value is below the minimum tolerance value (1.e-7), the algorithm will use the default internal fuzzy value from OCCT. |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
