Allows changing the tolerance in the shape and all of its sub shapes. More...
#include <GeomAlgoAPI_LimitTolerance.h>
Public Types | |
| GeomAlgoAPI_LimitTolerance (const GeomShapePtr theShape, const double theTolerance, const bool theCheckGeometry=false, const bool theExactAdjust=false) | |
| Constructor. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_LimitTolerance::GeomAlgoAPI_LimitTolerance | ( | const GeomShapePtr | theShape, |
| const double | theTolerance, | ||
| const bool | theCheckGeometry = false, |
| const bool | theExactAdjust = false |
| [in] | theShape | for which tolerance should be changed |
| [in] | theTolerance | the new tolerance |
| [in] | theCheckGeometry | if True, also check geometry |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
