Allows to create loft of two objects with same type. More...
#include <GeomAlgoAPI_Loft.h>
Public Types | |
| GeomAlgoAPI_Loft (const GeomShapePtr theFirstShape, const GeomShapePtr theSecondShape) | |
| Creates loft for two given shape with same type. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
It produces the following results from objects: 2 edges -> Face 2 Wire -> Shell 2 Face -> Solid
Builder type enum.
| GeomAlgoAPI_Loft::GeomAlgoAPI_Loft | ( | const GeomShapePtr | theFirstShape, |
| const GeomShapePtr | theSecondShape | ||
| [in] | theFirstShape | the first shape. |
| [in] | theSecondShape | the second shape. |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
