Creates non planar faces. More...
#include <GeomAlgoAPI_NonPlanarFace.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_NonPlanarFace (const ListOfShape &theEdges) |
| Creates list of faces based on the non-planar wires. More... | |
| GEOMALGOAPI_EXPORT const ListOfShape & | faces () const |
| Return list of created faces. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_NonPlanarFace::GeomAlgoAPI_NonPlanarFace | ( | const ListOfShape & | theEdges | ) |
| theEdges | list of input non-planar edges. |
inline |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
