GeomAlgoAPI_PaveFiller Class Reference
Finds the common parts from the list of shapes and breaks it to shapes with shared subshapes. More...
#include <GeomAlgoAPI_PaveFiller.h>
Inheritance diagram for GeomAlgoAPI_PaveFiller:
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_PaveFiller (const ListOfShape &theListOfShape, const bool theIsMakeCompSolids=false, const double theFuzzy=1.e-8)
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_PaveFiller()
GeomAlgoAPI_PaveFiller::GeomAlgoAPI_PaveFiller ( const ListOfShape &  theListOfShape,
const bool  theIsMakeCompSolids = false,
const double  theFuzzy = 1.e-8
[in]theListOfShapelist of shape which should be split.
[in]theIsMakeCompSolidsif true gather shapes with shared faces to compsolids.
[in]theFuzzyadditional tolerance value. If the fuzzy value is below the minimum tolerance value (1.e-7), the algorithm will use the default internal fuzzy value from OCCT.
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modified()
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
