SMESH_Gen_No_Session_i Class Reference
#include <SMESH_Gen_No_Session_i.hxx>
Inheritance diagram for SMESH_Gen_No_Session_i:
 SMESH_Gen_No_Session_i (CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName)
GEOM::GEOM_Gen_var GetGeomEngine (bool isShaper) override
SALOMEDS::Study_var getStudyServantVirtual () const override
SALOME_ModuleCatalog::ModuleCatalog_var getModuleCatalog () const override
SALOMEDS::Study_var getStudyServant () const
SALOMEDS::SObject_ptr publish (CORBA::Object_ptr theIOR, SALOMEDS::SObject_ptr theFatherObject, const int theTag=0, const char *thePixMap=0, const bool theSelectable=true)
SALOMEDS::SObject_ptr ObjectToSObject (CORBA::Object_ptr theObject)
void SetName (const char *theIOR, const char *theName)
 SMESH_Gen_i::SetName. More...
void SetName (SALOMEDS::SObject_ptr theSObject, const char *theName, const char *theDefaultName=0)
void SetGeomEngine (GEOM::GEOM_Gen_ptr geomcompo)
 SMESH_Gen_i::SetGeomEngine. More...
void SetEmbeddedMode (CORBA::Boolean theMode)
 SMESH_Gen_i::SetEmbeddedMode. More...
CORBA::Boolean IsEmbeddedMode ()
 SMESH_Gen_i::IsEmbeddedMode. More...
void SetEnablePublish (CORBA::Boolean theIsEnablePublish)
 SMESH_Gen_i::SetEnablePublish. More...
CORBA::Boolean IsEnablePublish ()
 SMESH_Gen_i::IsEnablePublish. More...
void UpdateStudy ()
 SMESH_Gen_i::UpdateStudy. More...
bool hasObjectInfo ()
char * getObjectInfo (const char *entry)
SMESH::SMESH_Hypothesis_ptr CreateHypothesis (const char *theHypType, const char *theLibName)
 SMESH_Gen_i::CreateHypothesis. More...
SMESH::SMESH_Hypothesis_ptr CreateHypothesisByAverageLength (const char *theHypType, const char *theLibName, CORBA::Double theAverageLength, CORBA::Boolean theQuadDominated)
 Return a hypothesis initialized by given average length. More...
SMESH::SMESH_Hypothesis_ptr GetHypothesisParameterValues (const char *theHypType, const char *theLibName, SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theGeom, const SMESH::HypInitParams &theWay)
 Return a hypothesis holding parameter values corresponding either to the mesh existing on the given geometry or to size of the geometry. More...
CORBA::Boolean GetSoleSubMeshUsingHyp (SMESH::SMESH_Hypothesis_ptr theHyp, SMESH::SMESH_Mesh_out theMesh, GEOM::GEOM_Object_out theShape)
 Returns True if a hypothesis is assigned to a sole sub-mesh in a current Study. More...
void SetBoundaryBoxSegmentation (CORBA::Long theNbSegments)
 Sets number of segments per diagonal of boundary box of geometry by which default segment length of appropriate 1D hypotheses is defined. More...
void SetDefaultNbSegments (CORBA::Long theNbSegments)
 Sets default number of segments per edge. More...
virtual void SetOption (const char *, const char *)
 Set an option value. More...
virtual char * GetOption (const char *)
 Return an option value. More...
bool ToForgetMeshDataOnHypModif () const
 To load full mesh data from study at hyp modification or not. More...
SMESH::SMESH_Mesh_ptr CreateMesh (GEOM::GEOM_Object_ptr theShapeObject)
 SMESH_Gen_i::CreateMesh. More...
SMESH::SMESH_ParallelMesh_ptr CreateParallelMesh (GEOM::GEOM_Object_ptr theShapeObject)
 SMESH_Gen_i::CreateParallelMesh. More...
SMESH::SMESH_Mesh_ptr CreateEmptyMesh ()
 SMESH_Gen_i::CreateEmptyMesh. More...
SMESH::SMESH_Mesh_ptr ReloadMeshFromFile (SMESH::SMESH_Mesh_ptr theMesh)
SMESH::SMESH_Mesh_ptr CreateMeshesFromUNV (const char *theFileName)
 SMESH_Gen_i::CreateMeshFromUNV. More...
SMESH::SMESH_Mesh_ptr ReloadMeshesFromUNV (const char *theFileName, SMESH::SMESH_Mesh_ptr sourceMesh)
SMESH::mesh_array * CreateMeshesFromMED (const char *theFileName, SMESH::DriverMED_ReadStatus &theStatus)
 SMESH_Gen_i::CreateMeshFromMED. More...
SMESH::mesh_array * ReloadMeshesFromMED (const char *theFileName, SMESH::SMESH_Mesh_ptr sourceMesh, SMESH::DriverMED_ReadStatus &theStatus)
SMESH::mesh_array * CreateMeshesFromMAIL (const char *theFileName, SMESH::DriverMED_ReadStatus &theStatus)
SMESH::mesh_array * CreateMeshesFromINP (const char *theFileName, SMESH::DriverMED_ReadStatus &theStatus) override
SMESH::mesh_array * CreateMeshesFromCDB (const char *theFileName, SMESH::DriverMED_ReadStatus &theStatus) override
SMESH::mesh_array * CreateMeshesFromASC (const char *theFileName, SMESH::DriverMED_ReadStatus &theStatus) override
SMESH::mesh_array * CreateMeshesFromGEOF (const char *theFileName, SMESH::DriverMED_ReadStatus &theStatus) override
SMESH::SMESH_Mesh_ptr CreateMeshesFromSTL (const char *theFileName)
 SMESH_Gen_i::CreateMeshFromSTL. More...
SMESH::SMESH_Mesh_ptr ReloadMeshesFromSTL (const char *theFileName, SMESH::SMESH_Mesh_ptr sourceMesh)
SMESH::mesh_array * CreateMeshesFromCGNS (const char *theFileName, SMESH::DriverMED_ReadStatus &theStatus)
 Create meshes and import data from the CGSN file. More...
SMESH::mesh_array * ReloadMeshesFromCGNS (const char *theFileName, SMESH::SMESH_Mesh_ptr sourceMesh, SMESH::DriverMED_ReadStatus &theStatus)
SMESH::SMESH_Mesh_ptr CreateMeshesFromGMF (const char *theFileName, CORBA::Boolean theMakeRequiredGroups, SMESH::ComputeError_out theError)
 Create a mesh and import data from a GMF file. More...
SMESH::SMESH_Mesh_ptr ReloadMeshesFromGMF (const char *theFileName, SMESH::SMESH_Mesh_ptr sourceMesh, CORBA::Boolean theMakeRequiredGroups, SMESH::ComputeError_out theError)
SMESH::mesh_array * CreateMeshesFromMESHIO (const char *theFileName, SMESH::DriverMED_ReadStatus &theStatus, const char *selectedFilter=nullptr, const char *converter=nullptr)
 Create a mesh and import data from any file supported by meshio library. More...
SMESH::mesh_array * ReloadMeshesFromMESHIO (const char *theFileName, SMESH::SMESH_Mesh_ptr sourceMesh, SMESH::DriverMED_ReadStatus &theStatus, const char *converter=nullptr)
SMESH::SMESH_Mesh_ptr CreateDualMesh (SMESH::SMESH_IDSource_ptr meshPart, const char *meshName, CORBA::Boolean adapt_to_shape)
 Create a mesh by copying a part of another mesh. More...
SMESH::SMESH_Mesh_ptr CopyMesh (SMESH::SMESH_IDSource_ptr meshPart, const char *meshName, CORBA::Boolean toCopyGroups, CORBA::Boolean toKeepIDs)
CORBA::Boolean CopyMeshWithGeom (SMESH::SMESH_Mesh_ptr sourceMesh, GEOM::GEOM_Object_ptr newGeometry, const char *meshName, CORBA::Boolean toCopyGroups, CORBA::Boolean toReuseHypotheses, CORBA::Boolean toCopyElements, SMESH::SMESH_Mesh_out newMesh, SMESH::ListOfGroups_out newGroups, SMESH::submesh_array_out newSubmeshes, SMESH::ListOfHypothesis_out newHypotheses, SMESH::string_array_out invalidEntries)
 Create a mesh by copying definitions of another mesh to a given geometry. More...
CORBA::Boolean Compute (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theShapeObject)
 SMESH_Gen_i::Compute. More...
void CancelCompute (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theShapeObject)
 SMESH_Gen_i::CancelCompute. More...
SMESH::compute_error_array * GetComputeErrors (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theShapeObject)
 Return errors of mesh computation. More...
SMESH::smIdType_array * Evaluate (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theShapeObject)
 Evaluate mesh on a shape and returns statistic of mesh elements Result array of number enityties. More...
CORBA::Boolean IsReadyToCompute (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theShapeObject)
 SMESH_Gen_i::IsReadyToCompute. More...
SMESH::MeshPreviewStruct * Precompute (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theSubObject, SMESH::Dimension theDimension, SMESH::long_array &theShapesId)
 Calculate Mesh as preview till indicated dimension on shape First, verify list of hypothesis associated with the subShape. More...
SMESH::algo_error_array * GetAlgoState (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theSubObject)
 Returns errors of hypotheses definition. More...
SMESH::MeshPreviewStruct * GetBadInputElements (SMESH::SMESH_Mesh_ptr theMesh, CORBA::Short theSubShapeID)
 Return mesh elements preventing computation of a subshape. More...
SMESH::ListOfGroups * MakeGroupsOfBadInputElements (SMESH::SMESH_Mesh_ptr theMesh, CORBA::Short theSubShapeID, const char *theGroupName)
 Create a group of elements preventing computation of a sub-shape. More...
SMESH::long_array * GetSubShapesId (GEOM::GEOM_Object_ptr theMainShapeObject, const SMESH::object_array &theListOfSubShape)
 SMESH_Gen_i::GetSubShapesId. More...
GEOM::GEOM_Object_ptr GetGeometryByMeshElement (SMESH::SMESH_Mesh_ptr theMesh, SMESH::smIdType theElementID, const char *theGeomName)
 Return geometrical object the given element is built on. More...
GEOM::GEOM_Object_ptr FindGeometryByMeshElement (SMESH::SMESH_Mesh_ptr theMesh, SMESH::smIdType theElementID)
SMESH::SMESH_Mesh_ptr ConcatenateCommon (const SMESH::ListOfIDSources &meshesArray, CORBA::Boolean uniteIdenticalGroups, CORBA::Boolean mergeNodesAndElements, CORBA::Double mergeTolerance, CORBA::Boolean commonGroups, SMESH::SMESH_Mesh_ptr meshToAppendTo)
 SMESH_Gen_i::ConcatenateCommon. More...
SMESH::SMESH_Mesh_ptr Concatenate (const SMESH::ListOfIDSources &meshesArray, CORBA::Boolean uniteIdenticalGroups, CORBA::Boolean mergeNodesAndElements, CORBA::Double mergeTolerance, SMESH::SMESH_Mesh_ptr meshToAppendTo)
 SMESH_Gen_i::Concatenate. More...
SMESH::SMESH_Mesh_ptr ConcatenateWithGroups (const SMESH::ListOfIDSources &meshesArray, CORBA::Boolean uniteIdenticalGroups, CORBA::Boolean mergeNodesAndElements, CORBA::Double mergeTolerance, SMESH::SMESH_Mesh_ptr meshToAppendTo)
 SMESH_Gen_i::ConcatenateWithGroups. More...
char * GetMEDFileVersion ()
 Get version of MED format being used. More...
char * GetMEDVersion (const char *theFileName)
 SMESH_Gen_i::GetMEDVersion. More...
CORBA::Boolean CheckCompatibility (const char *theFileName)
 SMESH_Gen_i::CheckCompatibility. More...
CORBA::Boolean CheckWriteCompatibility (const char *theFileName)
 SMESH_Gen_i::CheckWriteCompatibility. More...
SMESH::string_array * GetMeshNames (const char *theFileName)
 SMESH_Gen_i::GetMeshNames. More...
SALOMEDS::TMPFile * Save (SALOMEDS::SComponent_ptr theComponent, const char *theURL, bool isMultiFile)
 SMESH_Gen_i::Save. More...
bool Load (SALOMEDS::SComponent_ptr theComponent, const SALOMEDS::TMPFile &theStream, const char *theURL, bool isMultiFile)
 SMESH_Gen_i::Load. More...
SALOMEDS::TMPFile * SaveASCII (SALOMEDS::SComponent_ptr theComponent, const char *theURL, bool isMultiFile)
 SMESH_Gen_i::SaveASCII. More...
bool LoadASCII (SALOMEDS::SComponent_ptr theComponent, const SALOMEDS::TMPFile &theStream, const char *theURL, bool isMultiFile)
 SMESH_Gen_i::LoadASCII. More...
SMESH::FilterManager_ptr CreateFilterManager ()
 SMESH_Gen_i::CreateFilterManager. More...
SMESH::SMESH_Pattern_ptr GetPattern ()
 SMESH_Gen_i::GetPattern. More...
SMESH::Measurements_ptr CreateMeasurements ()
 SMESH_Gen_i::CreateMeasurements. More...
void Close (SALOMEDS::SComponent_ptr theComponent)
 SMESH_Gen_i::Close. More...
char * ComponentDataType ()
 SMESH_Gen_i::ComponentDataType. More...
char * IORToLocalPersistentID (SALOMEDS::SObject_ptr theSObject, const char *IORString, CORBA::Boolean isMultiFile, CORBA::Boolean isASCII)
 SMESH_Gen_i::IORToLocalPersistentID. More...
char * LocalPersistentIDToIOR (SALOMEDS::SObject_ptr theSObject, const char *aLocalPersistentID, CORBA::Boolean isMultiFile, CORBA::Boolean isASCII)
 SMESH_Gen_i::LocalPersistentIDToIOR. More...
bool CanPublishInStudy (CORBA::Object_ptr theIOR)
 SMESH_Gen_i::CanPublishInStudy. More...
SALOMEDS::SObject_ptr PublishInStudy (SALOMEDS::SObject_ptr theSObject, CORBA::Object_ptr theObject, const char *theName)
 SMESH_Gen_i::PublishInStudy. More...
CORBA::Boolean CanCopy (SALOMEDS::SObject_ptr)
SALOMEDS::TMPFile * CopyFrom (SALOMEDS::SObject_ptr, CORBA::Long &)
CORBA::Boolean CanPaste (const char *, CORBA::Long)
SALOMEDS::SObject_ptr PasteInto (const SALOMEDS::TMPFile &, CORBA::Long, SALOMEDS::SObject_ptr)
virtual char * getVersion ()
void AddToPythonScript (const TCollection_AsciiString &theString)
 AddToPythonScript - C++ Internal version. More...
virtual void AddToPythonScript (const char *theCommand)
 AddToPythonScript - CORBA Interface version (for Python plugins) More...
void PausePythonDumpRecording ()
 SMESH_Gen_i::PausePythonDumpRecording. More...
void ResumePythonDumpRecording ()
 SMESH_Gen_i::ResumePythonDumpRecording. More...
void RemoveLastFromPythonScript ()
 RemoveLastFromPythonScript. More...
void SavePython ()
TCollection_AsciiString DumpPython_impl (Resource_DataMapOfAsciiStringAsciiString &theObjectNames, Resource_DataMapOfAsciiStringAsciiString &theNames, bool isPublished, bool isMultiFile, bool isHistoricalDump, bool &aValidScript, TCollection_AsciiString &theSavedTrace)
 Creates a Dump Python script. More...
TCollection_AsciiString GetNewPythonLines ()
 GetNewPythonLines. More...
void CleanPythonTrace ()
 CleanPythonTrace. More...
int CountInPyDump (const TCollection_AsciiString &text)
 Count inclusions of a string in a raw Python dump script. More...
SMESH::MG_ADAPT_ptr CreateMG_ADAPT ()
 SMESH_Gen_i::CreateMG_ADAPT. More...
SMESHHOMARD::HOMARD_Gen_ptr CreateHOMARD_ADAPT ()
SMESH::MG_ADAPT_ptr CreateAdaptationHypothesis ()
SALOME::GenericObj_ptr Adaptation (const char *adaptationType)
GEOM_Client * GetShapeReader ()
 SMESH_Gen_i::GetShapeReader. More...
SALOMEDS::SComponent_ptr PublishComponent ()
SALOMEDS::SObject_ptr PublishMesh (SMESH::SMESH_Mesh_ptr theMesh, const char *theName=0, const char *thePixMap=0)
SALOMEDS::SObject_ptr PublishHypothesis (SMESH::SMESH_Hypothesis_ptr theHyp, const char *theName=0)
SALOMEDS::SObject_ptr PublishSubMesh (SMESH::SMESH_Mesh_ptr theMesh, SMESH::SMESH_subMesh_ptr theSubMesh, GEOM::GEOM_Object_ptr theShapeObject, const char *theName=0)
SALOMEDS::SObject_ptr PublishGroup (SMESH::SMESH_Mesh_ptr theMesh, SMESH::SMESH_GroupBase_ptr theGroup, GEOM::GEOM_Object_ptr theShapeObject, const char *theName=0)
void UpdateIcons (SMESH::SMESH_Mesh_ptr theMesh)
void UpdateGroupIcon (SMESH::SMESH_GroupBase_ptr theGroup)
void HighLightInvalid (CORBA::Object_ptr theObject, bool isInvalid)
bool IsInvalid (SALOMEDS::SObject_ptr theObject)
bool AddHypothesisToShape (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theShapeObject, SMESH::SMESH_Hypothesis_ptr theHyp)
bool RemoveHypothesisFromShape (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theShapeObject, SMESH::SMESH_Hypothesis_ptr theHyp)
SALOMEDS::SObject_ptr GetMeshOrSubmeshByShape (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theShape)
void SetPixMap (SALOMEDS::SObject_ptr theSObject, const char *thePixMap)
void addReference (SALOMEDS::SObject_ptr theSObject, CORBA::Object_ptr theToObject, int theTag=0)
StudyContext * GetStudyContext ()
 SMESH_Gen_i::GetStudyContext. More...
int RegisterObject (CORBA::Object_ptr theObject)
CORBA::Long GetObjectId (CORBA::Object_ptr theObject)
 Return id of registered object. More...
template<class TInterface >
TInterface::_var_type GetObjectByOldId (const int oldID)
SALOMEDS::SObject_ptr GetAlgoSO (const ::SMESH_Algo *algo)
 Find SObject for an algo. More...
void UpdateParameters (CORBA::Object_ptr theObject, const char *theParameters)
 Stores names of variables that WILL be passes as parameters when calling some method of a given object. More...
char * GetParameters (CORBA::Object_ptr theObject)
const std::vector< int > & GetLastParamIndices () const
const std::vector< std::string > & GetLastParameters () const
const std::string & GetLastObjEntry () const
std::vector< std::string > GetAllParameters (const std::string &theObjectEntry) const
 Return all variables used to create an object. More...
void Move (const SMESH::sobject_list &what, SALOMEDS::SObject_ptr where, CORBA::Long row)
CORBA::Boolean IsApplicable (const char *theAlgoType, const char *theLibName, GEOM::GEOM_Object_ptr theShapeObject, CORBA::Boolean toCheckAll)
SMESH::long_array * GetInsideSphere (SMESH::SMESH_IDSource_ptr meshPart, SMESH::ElementType theElemType, CORBA::Double theX, CORBA::Double theY, CORBA::Double theZ, CORBA::Double theR)
 Collect indices of elements, which are located inside the sphere. More...
SMESH::long_array * GetInsideBox (SMESH::SMESH_IDSource_ptr meshPart, SMESH::ElementType theElemType, CORBA::Double theX1, CORBA::Double theY1, CORBA::Double theZ1, CORBA::Double theX2, CORBA::Double theY2, CORBA::Double theZ2)
 Collect indices of elements, which are located inside the box. More...
SMESH::long_array * GetInsideCylinder (SMESH::SMESH_IDSource_ptr meshPart, SMESH::ElementType theElemType, CORBA::Double theX, CORBA::Double theY, CORBA::Double theZ, CORBA::Double theDX, CORBA::Double theDY, CORBA::Double theDZ, CORBA::Double theH, CORBA::Double theR)
 Collect indices of elements, which are located inside the cylinder. More...
SMESH::long_array * GetInside (SMESH::SMESH_IDSource_ptr meshPart, SMESH::ElementType theElemType, GEOM::GEOM_Object_ptr theGeom, CORBA::Double theTolerance)
 Collect indices of elements, which are located inside the geom object. More...
static SMESH_Gen_i * GetSMESHGen ()
static CORBA::ORB_var GetORB ()
static PortableServer::POA_var GetPOA ()
static void SetNS (SALOME_NamingService_Abstract *ns)
static SALOME_NamingService_Abstract * GetNS ()
 GetNS [ static ]. More...
static SALOME_LifeCycleCORBA * GetLCC ()
 GetLCC [ static ]. More...
static GEOM::GEOM_Gen_var GetGeomEngine (GEOM::GEOM_Object_ptr)
 GetGeomEngine [ static ]. More...
static PortableServer::ServantBase_var GetServant (CORBA::Object_ptr theObject)
 GetServant [ static ]. More...
static CORBA::Object_var SObjectToObject (SALOMEDS::SObject_ptr theSObject)
 SObjectToObject [ static ]. More...
static GEOM::GEOM_Object_ptr ShapeToGeomObject (const TopoDS_Shape &theShape)
static TopoDS_Shape GeomObjectToShape (GEOM::GEOM_Object_ptr theGeomObject)
static GEOM::GEOM_Object_ptr GetGeomObjectByEntry (const std::string &entry)
 Get GEOM Object by its study entry. More...
static long GetHypothesisRootTag ()
 Get...Tag [ static ]. More...
static long GetAlgorithmsRootTag ()
static long GetRefOnShapeTag ()
static long GetRefOnAppliedHypothesisTag ()
static long GetRefOnAppliedAlgorithmsTag ()
static long GetSubMeshOnVertexTag ()
static long GetSubMeshOnEdgeTag ()
static long GetSubMeshOnFaceTag ()
static long GetSubMeshOnSolidTag ()
static long GetSubMeshOnCompoundTag ()
static long GetSubMeshOnWireTag ()
static long GetSubMeshOnShellTag ()
static long GetNodeGroupsTag ()
static long GetEdgeGroupsTag ()
static long GetFaceGroupsTag ()
static long GetVolumeGroupsTag ()
static long Get0DElementsGroupsTag ()
static long GetBallElementsGroupsTag ()
Static Protected Attributes
static GEOM::GEOM_Gen_var myGeomGen
static SALOME_NamingService_Abstract * myNS = nullptr
SMESH::mesh_array * CreateMeshesFromMEDConverterInMedcoupling (const char *theFileName, SMESH::DriverMED_ReadStatus &theStatus, const std::string &converterPyFuncName)
GenericHypothesisCreator_i * getHypothesisCreator (const char *theHypName, const char *theLibName, std::string &thePlatformLibName)
 SMESH_Gen_i::getHypothesisCreator. More...
SMESH::SMESH_Hypothesis_ptr createHypothesis (const char *theHypName, const char *theLibName)
 SMESH_Gen_i::createHypothesis. More...
SMESH::SMESH_Mesh_ptr createMesh ()
 SMESH_Gen_i::createMesh. More...
SMESH::SMESH_ParallelMesh_ptr createParallelMesh ()
 SMESH_Gen_i::createParallelMesh. More...
bool isGeomModifIcon (SMESH::SMESH_Mesh_ptr mesh)
 Return true if mesh has ICON_SMESH_TREE_GEOM_MODIF icon. More...
SMESH::SMESH_subMesh_ptr createInvalidSubMesh (SMESH::SMESH_Mesh_ptr mesh, GEOM::GEOM_Object_ptr strangerGeom, const char *name)
 Create a sub-mesh on a geometry that is not a sub-shape of the main shape for the case where a valid sub-shape not found by CopyMeshWithGeom(). More...
void highLightInvalid (SALOMEDS::SObject_ptr theSObject, bool isInvalid)
std::vector< long > _GetInside (SMESH::SMESH_IDSource_ptr meshPart, SMESH::ElementType ElemType, const TopoDS_Shape &Shape, double *Tolerance=NULL)
 Collect indices of elements, which are located inside the TopoDS_Shape. More...
 Handle (TColStd_HSequenceOfAsciiString) myPythonScript
::SMESH_Gen myGen
std::map< std::string, GenericHypothesisCreator_i * > myHypCreatorMap
StudyContext * myStudyContext
GEOM_Client * myShapeReader
CORBA::Boolean myIsEmbeddedMode
CORBA::Boolean myIsEnablePublish
std::string myDefaultGroupColor
bool myToForgetMeshDataOnHypModif
bool myIsHistoricalPythonDump
std::vector< int > myLastParamIndex
std::vector< std::string > myLastParameters
std::string myLastObj
Static Private Attributes
static CORBA::ORB_var myOrb
static PortableServer::POA_var myPoa
static SALOME_LifeCycleCORBA * myLCC = nullptr
static SMESH_Gen_i * mySMESHGen = nullptr
◆ SMESH_Gen_No_Session_i()
SMESH_Gen_No_Session_i::SMESH_Gen_No_Session_i ( CORBA::ORB_ptr  orb,
const char *  instanceName,
const char *  interfaceName
References SMESH_Gen_i::myNS.
◆ _GetInside()
◆ Adaptation()
SALOME::GenericObj_ptr SMESH_Gen_i::Adaptation ( const char *  adaptationType)
◆ AddHypothesisToShape()
◆ addReference()
void SMESH_Gen_i::addReference ( SALOMEDS::SObject_ptr  theSObject,
int  theTag = 0
◆ AddToPythonScript() [1/2]
void SMESH_Gen_i::AddToPythonScript ( const char *  theCommand)
References SMESH_Gen_i::AddToPythonScript(), and MESSAGE.
◆ AddToPythonScript() [2/2]
void SMESH_Gen_i::AddToPythonScript ( const TCollection_AsciiString &  theString)
Referenced by SMESH_Gen_i::AddToPythonScript(), and SMESH::TPythonDump::~TPythonDump().
◆ CancelCompute()
void SMESH_Gen_i::CancelCompute ( SMESH::SMESH_Mesh_ptr  theMesh,
◆ CanCopy()
CORBA::Boolean SMESH_Gen_i::CanCopy ( SALOMEDS::SObject_ptr  )
◆ CanPaste()
CORBA::Boolean SMESH_Gen_i::CanPaste ( const char *  ,
CORBA::Long
◆ CanPublishInStudy()
◆ CheckCompatibility()
CORBA::Boolean SMESH_Gen_i::CheckCompatibility ( const char *  theFileName)
Check compatibility of file with MED format being used, read only.
References MED::CheckCompatibility().
◆ CheckWriteCompatibility()
CORBA::Boolean SMESH_Gen_i::CheckWriteCompatibility ( const char *  theFileName)
Check compatibility of file with MED format being used, for append on write.
◆ CleanPythonTrace()
void SMESH_Gen_i::CleanPythonTrace ( )
CleanPythonTrace.
Referenced by SMESH_Gen_i::Close(), and SMESH_Gen_i::SavePython().
◆ Close()
void SMESH_Gen_i::Close ( SALOMEDS::SComponent_ptr  theComponent)
◆ ComponentDataType()
◆ Compute()
◆ Concatenate()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::Concatenate ( const SMESH::ListOfIDSources &  theMeshesArray,
CORBA::Boolean  theUniteIdenticalGroups,
CORBA::Boolean  theMergeNodesAndElements,
CORBA::Double  theMergeTolerance,
SMESH::SMESH_Mesh_ptr  theMeshToAppendTo
Concatenate the given meshes into one mesh
References SMESH_Gen_i::ConcatenateCommon().
◆ ConcatenateCommon()
◆ ConcatenateWithGroups()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::ConcatenateWithGroups ( const SMESH::ListOfIDSources &  theMeshesArray,
Concatenate the given meshes into one mesh Create the groups of all elements from initial meshes
◆ CopyFrom()
SALOMEDS::TMPFile * SMESH_Gen_i::CopyFrom ( SALOMEDS::SObject_ptr  ,
CORBA::Long &
◆ CopyMesh()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::CopyMesh ( SMESH::SMESH_IDSource_ptr  meshPart,
const char *  meshName,
◆ CopyMeshWithGeom()
CORBA::Boolean SMESH_Gen_i::CopyMeshWithGeom ( SMESH::SMESH_Mesh_ptr  theSourceMesh,
GEOM::GEOM_Object_ptr  theNewGeometry,
const char *  theMeshName,
CORBA::Boolean  theToCopyGroups,
CORBA::Boolean  theToReuseHypotheses,
CORBA::Boolean  theToCopyElements,
SMESH::SMESH_Mesh_out  theNewMesh,
SMESH::ListOfGroups_out  theNewGroups,
SMESH::submesh_array_out  theNewSubmeshes,
SMESH::ListOfHypothesis_out  theNewHypotheses,
SMESH::string_array_out  theInvalidEntries
[in]sourceMesh- a mesh to copy
[in]newGeometry- a new geometry
[in]toCopyGroups- to create groups in the new mesh
[in]toReuseHypotheses- if True, existing hypothesis will be used by the new mesh, otherwise new hypotheses with the same parameters will be created for the new mesh.
[in]toCopyElements- to copy mesh elements of same sub-shapes of the two geometries
[out]newMesh- return a new mesh
[out]newGroups- return new groups
[out]newSubmeshes- return new sub-meshes
[out]newHypotheses- return new algorithms and hypotheses
[out]invalidEntries- return study entries of objects whose counterparts are not found in the newGeometry, followed by entries of mesh sub-objects that are invalid because they depend on a not found preceding sub-shape
CORBA::Boolean - is a success
References SMESH_MeshEditor::AddElement(), SMESHDS_Mesh::AddNodeWithID(), SMESH_subMesh::CHECK_COMPUTE_STATE, SMESHDS_Mesh::CompactMesh(), SMESH_subMesh::ComputeStateEngine(), SMESH_Gen_i::CreateFilterManager(), SMESH_Gen_i::CreateHypothesis(), SMESH_Gen_i::createInvalidSubMesh(), SMESH_Gen_i::CreateMesh(), SMESH::errorText(), SMDS_Mesh::FindNode(), SMESH::FT_BelongToCylinder, SMESH::FT_BelongToGenSurface, SMESH::FT_BelongToGeom, SMESH::FT_BelongToMeshGroup, SMESH::FT_BelongToPlane, SMESH::FT_ConnectedElements, SMESH::FT_LyingOnGeom, SMESH_subMesh::getDependsOnIterator(), SMESHDS_SubMesh::GetElements(), SMDS_Mesh::GetElementType(), SMDS_MeshElement::GetID(), SMESH_Mesh_i::GetImpl(), SMESH_Mesh::GetMeshDS(), SMDS_Mesh::GetMeshInfo(), SMESHDS_SubMesh::GetNodes(), SMESH_Hypothesis_i::getObjectsDependOn(), SMDS_MeshNode::GetPosition(), SMESH_Mesh::GetSubMeshContaining(), SMESH_subMesh::GetSubMeshDS(), SMESH_subMesh::GetSubShape(), SMESH_Gen_i::highLightInvalid(), SMESH_MeshEditor::ElemFeatures::Init(), SMESH_subMesh::IsEmpty(), SMESH_Mesh_i::Load(), SMESH_Hypothesis_i::LoadFrom(), SMDS_Mesh::Modified(), SMESH_MeshEditor::ElemFeatures::myNodes, SMDS_MeshInfo::NbElements(), SMDS_MeshElement::NbNodes(), SMESH::NODE, SMDS_MeshElement::nodeIterator(), SMESH_Gen_i::ObjectToSObject(), SMESH_Hypothesis_i::SaveTo(), SMESH_MeshEditor::ElemFeatures::SetID(), SMESHDS_Mesh::SetMeshElementOnShape(), SMESH_Gen_i::SetName(), SMESHDS_Mesh::SetNodeInVolume(), SMESHDS_Mesh::SetNodeOnEdge(), SMESHDS_Mesh::SetNodeOnFace(), SMESHDS_Mesh::SetNodeOnVertex(), SMESH_Hypothesis_i::setObjectsDependOn(), SMDS_TOP_3DSPACE, SMDS_TOP_EDGE, SMDS_TOP_FACE, SMDS_TOP_VERTEX, SMDSAbs_All, SMESH_CATCH, SMESH_TRY, and SMESH::throwCorbaException().
◆ CountInPyDump()
int SMESH_Gen_i::CountInPyDump ( const TCollection_AsciiString &  text)
References SMESH_Gen_i::ComponentDataType(), SMESH_Gen_i::GetSMESHGen(), and SMESH_Gen_i::getStudyServant().
◆ CreateAdaptationHypothesis()
SMESH::MG_ADAPT_ptr SMESH_Gen_i::CreateAdaptationHypothesis ( )
◆ CreateDualMesh()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::CreateDualMesh ( SMESH::SMESH_IDSource_ptr  mesh,
mesh- TetraHedron mesh
meshNameName of the created mesh
SMESH::SMESH_Mesh_ptr- the new mesh
References SMESH_Gen_i::CreateMesh(), SMESH_Mesh::GetGroupIds(), SMESH_Mesh_i::GetImpl(), SMESH_Mesh::GetMeshDS(), SMESH_Gen_i::GetORB(), SMESH_Mesh_i::ImportMEDFile(), MESSAGE, SMDS_Mesh::Modified(), SMESH_Gen_i::ObjectToSObject(), SMESH_Gen_i::SetName(), and SMESH_Gen_i::SetPixMap().
◆ CreateEmptyMesh()
◆ CreateFilterManager()
SMESH::FilterManager_ptr SMESH_Gen_i::CreateFilterManager ( )
◆ CreateHOMARD_ADAPT()
SMESHHOMARD::HOMARD_Gen_ptr SMESH_Gen_i::CreateHOMARD_ADAPT ( )
References MED::exists().
◆ createHypothesis()
◆ CreateHypothesis()
SMESH::SMESH_Hypothesis_ptr SMESH_Gen_i::CreateHypothesis ( const char *  theHypName,
const char *  theLibName
◆ CreateHypothesisByAverageLength()
SMESH::SMESH_Hypothesis_ptr SMESH_Gen_i::CreateHypothesisByAverageLength ( const char *  theHypType,
const char *  theLibName,
theHypType- hypothesis type name
theLibName- plugin library name
theAverageLength- average length
theQuadDominated- is quad-dominated flag
SMESH::SMESH_Hypothesis_ptr- the new hypothesis
References SMESH_Hypothesis::BY_AVERAGE_LENGTH, SMESH_Gen_i::GetHypothesisParameterValues(), and SMESH_Gen_i::PublishHypothesis().
◆ createInvalidSubMesh()
SMESH::SMESH_subMesh_ptr SMESH_Gen_i::createInvalidSubMesh ( SMESH::SMESH_Mesh_ptr  theMesh,
GEOM::GEOM_Object_ptr  theStrangerGeom,
const char *  theName
privateinherited
The invalid sub-mesh has GetId() < 0.
References SMESH_Gen_i::CanPublishInStudy(), SMESH_Mesh_i::createSubMesh(), SMESH_Gen_i::GetRefOnShapeTag(), SMESH_Gen_i::getStudyServant(), and SMESH_Gen_i::PublishSubMesh().
Referenced by SMESH_Gen_i::CopyMeshWithGeom().
◆ CreateMeasurements()
SMESH::Measurements_ptr SMESH_Gen_i::CreateMeasurements ( )
Create measurement instance
◆ createMesh()
◆ CreateMesh()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::CreateMesh ( GEOM::GEOM_Object_ptr  theShapeObject)
◆ CreateMeshesFromASC()
SMESH::mesh_array * SMESH_Gen_i::CreateMeshesFromASC ( const char *  theFileName,
SMESH::DriverMED_ReadStatus &  theStatus
overrideinherited
◆ CreateMeshesFromCDB()
SMESH::mesh_array * SMESH_Gen_i::CreateMeshesFromCDB ( const char *  theFileName,
overrideinherited
◆ CreateMeshesFromCGNS()
◆ CreateMeshesFromGEOF()
SMESH::mesh_array * SMESH_Gen_i::CreateMeshesFromGEOF ( const char *  theFileName,
overrideinherited
◆ CreateMeshesFromGMF()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::CreateMeshesFromGMF ( const char *  theFileName,
◆ CreateMeshesFromINP()
SMESH::mesh_array * SMESH_Gen_i::CreateMeshesFromINP ( const char *  theFileName,
overrideinherited
◆ CreateMeshesFromMAIL()
SMESH::mesh_array * SMESH_Gen_i::CreateMeshesFromMAIL ( const char *  theFileName,
Create mesh and import data from MED file
References SMESH_Gen_i::CreateMeshesFromMEDConverterInMedcoupling().
◆ CreateMeshesFromMED()
◆ CreateMeshesFromMEDConverterInMedcoupling()
SMESH::mesh_array * SMESH_Gen_i::CreateMeshesFromMEDConverterInMedcoupling ( const char *  theFileName,
SMESH::DriverMED_ReadStatus &  theStatus,
const std::string &  converterPyFuncName
privateinherited
◆ CreateMeshesFromMESHIO()
◆ CreateMeshesFromSTL()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::CreateMeshesFromSTL ( const char *  theFileName)
◆ CreateMeshesFromUNV()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::CreateMeshesFromUNV ( const char *  theFileName)
◆ CreateMG_ADAPT()
SMESH::MG_ADAPT_ptr SMESH_Gen_i::CreateMG_ADAPT ( )
◆ createParallelMesh()
SMESH::SMESH_ParallelMesh_ptr SMESH_Gen_i::createParallelMesh ( )
privateinherited
◆ CreateParallelMesh()
SMESH::SMESH_ParallelMesh_ptr SMESH_Gen_i::CreateParallelMesh ( GEOM::GEOM_Object_ptr  theShapeObject)
◆ DumpPython()
Engines::TMPFile * SMESH_Gen_i::DumpPython ( CORBA::Boolean  isPublished,
◆ DumpPython_impl()
TCollection_AsciiString SMESH_Gen_i::DumpPython_impl ( Resource_DataMapOfAsciiStringAsciiString &  theObjectNames,
Resource_DataMapOfAsciiStringAsciiString &  theNames,
bool  isPublished,
bool  isMultiFile,
bool &  aValidScript,
TCollection_AsciiString &  theSavedTrace
[in,out]theObjectNames- map of an entry to a study and python name
[in]theNames- - map of an entry to a study name
[in]isPublished- true if dump of object publication in study is needed
[in]isMultiFile- true if dump of each module goes to a separate file
[in]isHistoricalDump- true if removed object should be dumped
[out]aValidScript- returns true if the returned script seems valid
[in,out]theSavedTrace- the dump stored in the study. It's cleared to decrease memory usage.
TCollection_AsciiString - the result dump script.
References SMESH_Gen_i::ComponentDataType(), SMESH_2smeshpy::ConvertScript(), SMESH::TPythonDump::CutoutLongString(), end(), SMESH_2smeshpy::GenName(), SMESH_Gen_i::GetGeomEngine(), SMESH_Gen_i::getStudyServant(), SMESH_Gen_i::Handle(), SMESH::TPythonDump::NotPublishedObjectName(), SMESH::printException(), SMESH::TVar::Quote(), SMESH_CATCH, SMESH_TRY, SMESH::TPythonDump::SMESHGenName(), and SMESH_2smeshpy::SmeshpyName().
Referenced by SMESH_Gen_i::DumpPython().
◆ Evaluate()
SMESH::smIdType_array * SMESH_Gen_i::Evaluate ( SMESH::SMESH_Mesh_ptr  theMesh,
◆ FindGeometryByMeshElement()
GEOM::GEOM_Object_ptr SMESH_Gen_i::FindGeometryByMeshElement ( SMESH::SMESH_Mesh_ptr  theMesh,
theMesh- the mesh the element is in
theElementID- the element ID
GEOM::GEOM_Object_ptr- the found or created (UnRegister()!) geom object
References SMDS_Mesh::FindElement(), SMESH_Gen_i::GeomObjectToShape(), SMESH_Gen_i::GetGeomEngine(), SMESH_Mesh_i::GetImpl(), SMESH_Mesh::GetMeshDS(), SMESH_Gen_i::getStudyServant(), SMESHDS_Mesh::IndexToShape(), SMESH_Gen_i::ObjectToSObject(), SMESH_Gen_i::ShapeToGeomObject(), and SMESH_Gen_i::SObjectToObject().
Referenced by SMESH_Gen_i::GetGeometryByMeshElement().
◆ GeomObjectToShape()
TopoDS_Shape SMESH_Gen_i::GeomObjectToShape ( GEOM::GEOM_Object_ptr  theGeomObject)
References SMESH_Gen_i::GetGeomEngine(), SMESH_Gen_i::GetShapeReader(), and SMESH_Gen_i::mySMESHGen.
Referenced by SMESH_Mesh_i::addHypothesis(), SMESH_Gen_i::AddHypothesisToShape(), SMESH_MeshEditor_i::AffectedElemGroupsInRegion(), SMESH_Pattern_i::ApplyTo3DBlock(), SMESH_Pattern_i::ApplyToFace(), SMESH_Gen_i::CancelCompute(), SMESH_Mesh_i::CheckGeomModif(), SMESH_Gen_i::Compute(), StdMeshers_CartesianParameters3D_i::ComputeOptimalAxesDirs(), SMESH_Mesh_i::CreateGroupFromGEOM(), SMESH_MeshEditor_i::CreateHoleSkin(), SMESH_Mesh_i::createSubMesh(), SMESH_MeshEditor_i::DoubleNodeElemGroupInRegion(), SMESH_MeshEditor_i::DoubleNodeElemGroupsInRegion(), SMESH_MeshEditor_i::DoubleNodeElemInRegion(), SMESH_Gen_i::Evaluate(), SMESH_MeshEditor_i::ExtrusionAlongPathObjects(), SMESH_Gen_i::FindGeometryByMeshElement(), SMESH_Gen_i::GetAlgoState(), SMESH_Gen_i::GetComputeErrors(), SMESH_Mesh_i::GetHypothesisList(), SMESH_Gen_i::GetHypothesisParameterValues(), SMESH_Gen_i::GetInside(), SMESH_Gen_i::GetMeshOrSubmeshByShape(), getShapeByID(), getShapeByName(), SMESH_Mesh_i::GetSubMesh(), SMESH_Gen_i::GetSubShapesId(), SMESH_Gen_i::IsApplicable(), SMESH_Gen_i::IsReadyToCompute(), SMESH_MeshEditor_i::LinearAnglesVariation(), SMESH_Gen_i::Load(), SMESH_Pattern_i::LoadFrom3DBlock(), SMESH_Pattern_i::LoadFromFace(), SMESH_Mesh_i::newGroupShape(), SMESH_Gen_i::Precompute(), SMESH_Mesh_i::removeHypothesis(), SMESH::BelongToGeom_i::SetGeom(), SMESH::LyingOnGeom_i::SetGeom(), SMESH_Mesh_i::SetShape(), SMESH::BelongToSurface_i::SetSurface(), SMESH::BelongToGenSurface_i::SetSurface(), and SMESH::ConnectedElements_i::SetVertex().
◆ Get0DElementsGroupsTag()
long SMESH_Gen_i::Get0DElementsGroupsTag ( )
◆ GetAlgorithmsRootTag()
long SMESH_Gen_i::GetAlgorithmsRootTag ( )
◆ GetAlgoSO()
◆ GetAlgoState()
SMESH::algo_error_array * SMESH_Gen_i::GetAlgoState ( SMESH::SMESH_Mesh_ptr  theMesh,
◆ GetAllParameters()
std::vector< std::string > SMESH_Gen_i::GetAllParameters ( const std::string &  theObjectEntry) const
[in]theObjectEntry- an object entry in the current study
std::vector< std::string > - all variable names (or values of removed variables)
References SMESH_Gen_i::getStudyServant().
Referenced by SMESH_NoteBook::InitObjectMap().
◆ GetBadInputElements()
SMESH::MeshPreviewStruct * SMESH_Gen_i::GetBadInputElements ( SMESH::SMESH_Mesh_ptr  theMesh,
◆ GetBallElementsGroupsTag()
long SMESH_Gen_i::GetBallElementsGroupsTag ( )
◆ GetComputeErrors()
◆ GetEdgeGroupsTag()
long SMESH_Gen_i::GetEdgeGroupsTag ( )
◆ GetFaceGroupsTag()
long SMESH_Gen_i::GetFaceGroupsTag ( )
◆ GetGeomEngine() [1/2]
GEOM::GEOM_Gen_var SMESH_Gen_No_Session_i::GetGeomEngine ( bool  isShaper)
overridevirtual
Implements SMESH_Gen_i.
References SMESH_Gen_i::myGeomGen.
◆ GetGeomEngine() [2/2]
GEOM::GEOM_Gen_var SMESH_Gen_i::GetGeomEngine ( GEOM::GEOM_Object_ptr  go)
◆ GetGeometryByMeshElement()
GEOM::GEOM_Object_ptr SMESH_Gen_i::GetGeometryByMeshElement ( SMESH::SMESH_Mesh_ptr  theMesh,
const char *  theGeomName
theGeomName- the name of the result geom object if it is not yet published
GEOM::GEOM_Object_ptr- the found or just published geom object (no need to UnRegister())
References SMESH_Gen_i::FindGeometryByMeshElement(), SMESH_Gen_i::GetGeomEngine(), SMESH_Gen_i::getStudyServant(), SMESH_Gen_i::ObjectToSObject(), and SMESH_Gen_i::SObjectToObject().
◆ GetGeomObjectByEntry()
GEOM::GEOM_Object_ptr SMESH_Gen_i::GetGeomObjectByEntry ( const std::string &  entry)
References SMESH_Gen_i::getStudyServant(), SMESH_Gen_i::mySMESHGen, and SMESH_Gen_i::SObjectToObject().
◆ getHypothesisCreator()
GenericHypothesisCreator_i * SMESH_Gen_i::getHypothesisCreator ( const char *  theHypName,
std::string &  thePlatformLibName
privateinherited
◆ GetHypothesisParameterValues()
SMESH::SMESH_Hypothesis_ptr SMESH_Gen_i::GetHypothesisParameterValues ( const char *  theHypType,
const SMESH::HypInitParams &  theParams
◆ GetHypothesisRootTag()
long SMESH_Gen_i::GetHypothesisRootTag ( )
Methods which determine SMESH data model structure
References SMESH::Tag_HypothesisRoot.
Referenced by SMESH_Mesh_i::onHypothesisModified(), SMESH_Gen_i::PublishHypothesis(), and SMESH_Gen_i::Save().
◆ GetInside()
SMESH::long_array * SMESH_Gen_i::GetInside ( SMESH::SMESH_IDSource_ptr  meshPart,
References SMESH_Gen_i::_GetInside(), and SMESH_Gen_i::GeomObjectToShape().
◆ GetInsideBox()
SMESH::long_array * SMESH_Gen_i::GetInsideBox ( SMESH::SMESH_IDSource_ptr  meshPart,
CORBA::Double  theZ2
References SMESH_Gen_i::_GetInside().
◆ GetInsideCylinder()
SMESH::long_array * SMESH_Gen_i::GetInsideCylinder ( SMESH::SMESH_IDSource_ptr  meshPart,
CORBA::Double  theX,
CORBA::Double  theY,
CORBA::Double  theZ,
CORBA::Double  theH,
CORBA::Double  theR
◆ GetInsideSphere()
SMESH::long_array * SMESH_Gen_i::GetInsideSphere ( SMESH::SMESH_IDSource_ptr  meshPart,
CORBA::Double  theX,
CORBA::Double  theY,
CORBA::Double  theZ,
CORBA::Double  theR
◆ GetLastObjEntry()
const std::string & SMESH_Gen_i::GetLastObjEntry ( ) const
◆ GetLastParameters()
const std::vector< std::string > & SMESH_Gen_i::GetLastParameters ( ) const
◆ GetLastParamIndices()
const std::vector< int > & SMESH_Gen_i::GetLastParamIndices ( ) const
◆ GetLCC()
SALOME_LifeCycleCORBA * SMESH_Gen_i::GetLCC ( )
GetLCC [ static ].
Get SALOME_LifeCycleCORBA object
References SMESH_Gen_i::GetNS(), and SMESH_Gen_i::myLCC.
Referenced by SMESH_Gen_Session_i::GetGeomEngine().
◆ GetMEDFileVersion()
char * SMESH_Gen_i::GetMEDFileVersion ( )
References MED::GetVersionRelease().
◆ GetMEDVersion()
char * SMESH_Gen_i::GetMEDVersion ( const char *  theFileName)
Get MED version of the file by its name
References MED::GetMEDVersion().
◆ GetMeshNames()
SMESH::string_array * SMESH_Gen_i::GetMeshNames ( const char *  theFileName)
Get names of meshes defined in file with the specified name
References MED::CrWrapperR().
◆ GetMeshOrSubmeshByShape()
◆ getModuleCatalog()
SALOME_ModuleCatalog::ModuleCatalog_var SMESH_Gen_No_Session_i::getModuleCatalog ( ) const
overridevirtual
◆ GetNewPythonLines()
TCollection_AsciiString SMESH_Gen_i::GetNewPythonLines ( )
GetNewPythonLines.
References SMESH_Gen_i::Handle().
Referenced by SMESH_Gen_i::SavePython().
◆ GetNodeGroupsTag()
long SMESH_Gen_i::GetNodeGroupsTag ( )
◆ GetNS()
SALOME_NamingService_Abstract * SMESH_Gen_i::GetNS ( )
◆ GetObjectByOldId()
TInterface::_var_type SMESH_Gen_i::GetObjectByOldId ( const int  oldID)
◆ GetObjectId()
CORBA::Long SMESH_Gen_i::GetObjectId ( CORBA::Object_ptr  theObject)
theObject- the Object
int- Object id
References StudyContext::findId(), SMESH_Gen_i::GetORB(), and SMESH_Gen_i::myStudyContext.
◆ getObjectInfo()
char * SMESH_Gen_i::getObjectInfo ( const char *  entry)
◆ GetOption()
char * SMESH_Gen_i::GetOption ( const char *  name)
◆ GetORB()
◆ GetParameters()
char * SMESH_Gen_i::GetParameters ( CORBA::Object_ptr  theObject)
◆ GetPattern()
SMESH::SMESH_Pattern_ptr SMESH_Gen_i::GetPattern ( )
Create pattern mapper
◆ GetPOA()
◆ GetRefOnAppliedAlgorithmsTag()
long SMESH_Gen_i::GetRefOnAppliedAlgorithmsTag ( )
◆ GetRefOnAppliedHypothesisTag()
long SMESH_Gen_i::GetRefOnAppliedHypothesisTag ( )
◆ GetRefOnShapeTag()
◆ GetServant()
◆ GetShapeReader()
◆ GetSMESHGen()
static SMESH_Gen_i * SMESH_Gen_i::GetSMESHGen ( )
Referenced by _pyGen::_pyGen(), SMESH_MeshEditor_i::AffectedElemGroupsInRegion(), SMESH::MG_ADAPT_i::compute(), StdMeshers_CartesianParameters3D_i::ComputeOptimalAxesDirs(), SMESH_Mesh_i::ConvertToStandalone(), SMESH_Gen_i::CountInPyDump(), SMESH_MeshEditor_i::CreateHoleSkin(), SMESHGUI_MeshOp::createMesh(), SMESHHOMARD_I::HOMARD_Gen_i::DeleteResultInSmesh(), SMESH_MeshEditor_i::DoubleNodeElemGroupInRegion(), SMESH_MeshEditor_i::DoubleNodeElemGroupsInRegion(), SMESH_MeshEditor_i::DoubleNodeElemInRegion(), StdMeshers_ObjRefUlils::EntryOrShapeToGeomObject(), StdMeshers_ObjRefUlils::EntryToShape(), SMESH_MeshEditor_i::ExtrusionAlongPathObjects(), SMESH_PreMeshInfo::ForgetOrLoad(), SMESH_Mesh_i::generateMeshName(), StdMeshers_ObjRefUlils::GeomObjectToShape(), StdMeshersGUI_SubShapeSelectorWdg::GetGeomObjectByEntry(), SMESH::BelongToMeshGroup_i::GetGroup(), SMESH_Mesh_i::GetLastParameters(), SMESH_Mesh_i::GetParameters(), SMESH_NoteBook::GetReal(), getShapeByID(), getShapeByName(), SMESH_Hypothesis_i::GetVarParameter(), SMESH_NoteBook::InitObjectMap(), SMESH_Hypothesis_i::IsPublished(), SMESH_MeshEditor_i::LinearAnglesVariation(), StdMeshers_LayerDistribution_i::LoadFrom(), StdMeshers_ObjRefUlils::LoadFromStream(), StdMeshers_ObjRefUlils::LoadObjectFromStream(), SMESH_MeshEditor_i::MakeBoundaryElements(), SMESH_MeshEditor_i::makeMesh(), SMESH_MeshEditor_i::Offset(), SMESH::TPythonDump::operator<<(), SMESH_Mesh_i::prepareMeshNameAndGroups(), SMESHHOMARD_I::HOMARD_Gen_i::PublishResultInSmesh(), SMESHHOMARD_I::HOMARD_Gen_i::PythonDump(), SMESH_Mesh_i::RemoveGroup(), SMESH_PreMeshInfo::RemoveStudyFiles_TMP_METHOD(), SMESH_NoteBook::ReplaceVariables(), StdMeshers_ImportSource1D_i::SaveTo(), StdMeshers_ImportSource2D_i::SaveTo(), StdMeshers_ObjRefUlils::SaveToStream(), SMESH::BelongToGeom_i::SetGeom(), SMESH::LyingOnGeom_i::SetGeom(), SMESH::BelongToMeshGroup_i::SetGroupID(), StdMeshers_LayerDistribution_i::SetLayerDistribution(), SMESH_Hypothesis_i::setOldParameters(), SMESH_Mesh_i::SetParameters(), StdMeshers_ImportSource1D_i::SetSourceEdges(), StdMeshers_ImportSource2D_i::SetSourceFaces(), SMESH::BelongToSurface_i::SetSurface(), SMESH::BelongToGenSurface_i::SetSurface(), SMESH::ConnectedElements_i::SetThreshold(), SMESH_Hypothesis_i::SetVarParameter(), SMESH::ConnectedElements_i::SetVertex(), StdMeshers_ObjRefUlils::ShapeToGeomObject(), SPADDERPluginTester_i::testsmesh(), and SMESH::TPythonDump::~TPythonDump().
◆ GetSoleSubMeshUsingHyp()
CORBA::Boolean SMESH_Gen_i::GetSoleSubMeshUsingHyp ( SMESH::SMESH_Hypothesis_ptr  theHyp,
[in]theHyp- the hypothesis of interest
[out]theMesh- the sole mesh using theHyp
[out]theShape- the sole geometry theHyp is assigned to
boolean - True if theMesh and theShape are sole using theHyp
If two meshes on same shape have theHyp assigned to the same sub-shape, they are considered as SAME sub-mesh => result is true. This method ids used to initialize SMESHGUI_GenericHypothesisCreator with a shape to which an hyp being edited is assigned.
References SMESH_Gen_i::ComponentDataType(), SMESHDS_Mesh::GetHypotheses(), SMESH_Mesh_i::GetImpl(), SMESH_Mesh::GetMeshDS(), SMESH_Mesh_i::GetShapeToMesh(), SMESH_Gen_i::getStudyServant(), SMESH_Mesh_i::HasShapeToMesh(), SMESH_Gen_i::ShapeToGeomObject(), and SMESH_Gen_i::SObjectToObject().
◆ GetStudyContext()
StudyContext * SMESH_Gen_i::GetStudyContext ( )
◆ getStudyServant()
SALOMEDS::Study_var SMESH_Gen_i::getStudyServant ( ) const
Referenced by _pyGen::_pyGen(), SMESH_Gen_i::addReference(), SMESH_Gen_i::CanPublishInStudy(), SMESH_Mesh_i::CheckGeomGroupModif(), SMESH_Mesh_i::CheckGeomModif(), SMESH_Mesh_i::ConvertToStandalone(), SMESH_Gen_i::CountInPyDump(), SMESH_Gen_i::CreateEmptyMesh(), SMESH_Gen_i::createInvalidSubMesh(), SMESH_Gen_i::CreateMesh(), SMESH_Gen_i::CreateMeshesFromCGNS(), SMESH_Gen_i::CreateMeshesFromGMF(), SMESH_Gen_i::CreateMeshesFromMED(), SMESH_Gen_i::CreateMeshesFromMESHIO(), SMESH_Gen_i::CreateMeshesFromSTL(), SMESH_Gen_i::CreateMeshesFromUNV(), SMESH_Gen_i::CreateParallelMesh(), SMESHHOMARD_I::HOMARD_Gen_i::DeleteResultInSmesh(), SMESH_Gen_i::DumpPython(), SMESH_Gen_i::DumpPython_impl(), StdMeshers_ObjRefUlils::EntryOrShapeToGeomObject(), StdMeshers_ObjRefUlils::EntryToShape(), SMESH_Gen_i::FindGeometryByMeshElement(), SMESH_Mesh_i::generateMeshName(), SMESH_Gen_i::GetAlgoSO(), SMESH_Gen_i::GetAllParameters(), SMESH_Gen_i::GetGeometryByMeshElement(), StdMeshersGUI_SubShapeSelectorWdg::GetGeomObjectByEntry(), SMESH_Gen_i::GetGeomObjectByEntry(), SMESH_Mesh_i::GetLastParameters(), SMESH_Gen_i::getObjectInfo(), SMESH_NoteBook::GetReal(), getShapeByID(), getShapeByName(), SMESH_Mesh_i::GetShapeToMesh(), SMESH_Gen_i::GetSoleSubMeshUsingHyp(), SMESH_Gen_i::highLightInvalid(), SMESH_NoteBook::InitObjectMap(), SMESH_Gen_i::IsInvalid(), SMESH_Gen_i::Load(), StdMeshers_ObjRefUlils::LoadFromStream(), SMESH_Gen_i::Move(), SMESH_Mesh_i::newGroupShape(), SMESH_Gen_i::ObjectToSObject(), SMESH_MeshEditor_i::Offset(), SMESH_Mesh_i::onHypothesisModified(), SMESH_Mesh_i::prepareMeshNameAndGroups(), SMESH_Gen_i::publish(), SMESH_Gen_i::PublishComponent(), SMESHHOMARD_I::HOMARD_Gen_i::PublishResultInSmesh(), SMESH_Gen_i::PublishSubMesh(), SMESH_Gen_i::ReloadMeshesFromCGNS(), SMESH_Gen_i::ReloadMeshesFromGMF(), SMESH_Gen_i::ReloadMeshesFromMED(), SMESH_Gen_i::ReloadMeshesFromMESHIO(), SMESH_Gen_i::ReloadMeshesFromSTL(), SMESH_Gen_i::ReloadMeshesFromUNV(), SMESH_Gen_i::ReloadMeshFromFile(), SMESH_Mesh_i::RemoveGroup(), SMESH_Gen_i::RemoveHypothesisFromShape(), SMESH_PreMeshInfo::RemoveStudyFiles_TMP_METHOD(), SMESH_Mesh_i::RemoveSubMesh(), SMESH_Mesh_i::ReplaceShape(), SMESH_NoteBook::ReplaceVariables(), SMESH_Gen_i::Save(), SMESH_Gen_i::SavePython(), StdMeshers_ImportSource1D_i::SaveTo(), StdMeshers_ImportSource2D_i::SaveTo(), SMESH::BelongToMeshGroup_i::SetGroupID(), StdMeshers_LayerDistribution_i::SetLayerDistribution(), SMESH_Gen_i::SetName(), SMESH_Gen_i::SetPixMap(), SMESH::ConnectedElements_i::SetThreshold(), SMESH_Gen_i::UpdateIcons(), SMESH_Gen_i::UpdateParameters(), and SMESH_Gen_i::UpdateStudy().
◆ getStudyServantVirtual()
SALOMEDS::Study_var SMESH_Gen_No_Session_i::getStudyServantVirtual ( ) const
overridevirtual
◆ GetSubMeshOnCompoundTag()
long SMESH_Gen_i::GetSubMeshOnCompoundTag ( )
◆ GetSubMeshOnEdgeTag()
long SMESH_Gen_i::GetSubMeshOnEdgeTag ( )
◆ GetSubMeshOnFaceTag()
long SMESH_Gen_i::GetSubMeshOnFaceTag ( )
◆ GetSubMeshOnShellTag()
long SMESH_Gen_i::GetSubMeshOnShellTag ( )
◆ GetSubMeshOnSolidTag()
long SMESH_Gen_i::GetSubMeshOnSolidTag ( )
◆ GetSubMeshOnVertexTag()
long SMESH_Gen_i::GetSubMeshOnVertexTag ( )
◆ GetSubMeshOnWireTag()
long SMESH_Gen_i::GetSubMeshOnWireTag ( )
◆ GetSubShapesId()
SMESH::long_array * SMESH_Gen_i::GetSubShapesId ( GEOM::GEOM_Object_ptr  theMainShapeObject,
const SMESH::object_array &  theListOfSubShapeObject
Get sub-shapes unique ID's list
References Edge, Face, SMESH_Gen_i::GeomObjectToShape(), and MESSAGE.
◆ getVersion()
char * SMESH_Gen_i::getVersion ( )
◆ GetVolumeGroupsTag()
long SMESH_Gen_i::GetVolumeGroupsTag ( )
◆ Handle()
SMESH_Gen_i::Handle ( TColStd_HSequenceOfAsciiString  )
privateinherited
◆ hasObjectInfo()
bool SMESH_Gen_i::hasObjectInfo ( )
◆ HighLightInvalid()
void SMESH_Gen_i::HighLightInvalid ( CORBA::Object_ptr  theObject,
bool  isInvalid
◆ highLightInvalid()
void SMESH_Gen_i::highLightInvalid ( SALOMEDS::SObject_ptr  theSObject,
bool  isInvalid
privateinherited
◆ IORToLocalPersistentID()
char * SMESH_Gen_i::IORToLocalPersistentID ( SALOMEDS::SObject_ptr  theSObject,
const char *  IORString,
Transform data from transient form to persistent
References StudyContext::findId(), MESSAGE, and SMESH_Gen_i::myStudyContext.
◆ IsApplicable()
CORBA::Boolean SMESH_Gen_i::IsApplicable ( const char *  theAlgoType,
◆ IsEmbeddedMode()
CORBA::Boolean SMESH_Gen_i::IsEmbeddedMode ( )
◆ IsEnablePublish()
CORBA::Boolean SMESH_Gen_i::IsEnablePublish ( )
Check enable publishing
References SMESH_Gen_i::myIsEnablePublish.
◆ isGeomModifIcon()
bool SMESH_Gen_i::isGeomModifIcon ( SMESH::SMESH_Mesh_ptr  mesh)
privateinherited
References SMESH_Gen_i::ObjectToSObject().
Referenced by SMESH_Gen_i::Compute(), and SMESH_Gen_i::getObjectInfo().
◆ IsInvalid()
bool SMESH_Gen_i::IsInvalid ( SALOMEDS::SObject_ptr  theObject)
◆ IsReadyToCompute()
CORBA::Boolean SMESH_Gen_i::IsReadyToCompute ( SMESH::SMESH_Mesh_ptr  theMesh,
◆ Load()
bool SMESH_Gen_i::Load ( SALOMEDS::SComponent_ptr  theComponent,
const SALOMEDS::TMPFile &  theStream,
const char *  theURL,
bool  isMultiFile
SMESH_Gen_i::Load.
Load SMESH module's data
References SMESH_Mesh_i::addHypothesis(), SMESH_Mesh_i::createGroup(), SMESH_Gen_i::createHypothesis(), SMESH_Gen_i::createMesh(), SMESH_Mesh_i::createSubMesh(), SMESH_Mesh_i::FileInfoFromString(), StudyContext::findId(), SMESH_Gen_i::GeomObjectToShape(), SMESHUtils::ArrayDeleter< TOBJ >::get(), SMESH_Gen_i::Get0DElementsGroupsTag(), SMESH_Gen_i::GetBallElementsGroupsTag(), SMESH_Gen_i::GetEdgeGroupsTag(), SMESH_Gen_i::GetFaceGroupsTag(), SMESH_Gen_i::GetGeomObjectByEntry(), SMESH_GroupBase_i::GetGroupDS(), SMESH_Mesh_i::GetImpl(), StudyContext::getIORbyOldId(), SMESH_Mesh::GetMeshDS(), SMESH_Gen_i::GetNodeGroupsTag(), StudyContext::getOldId(), SMESH_Gen_i::GetORB(), SMESH_GroupOnFilter_i::GetPredicate(), SMESH_Gen_i::GetServant(), SMESH_Mesh_i::GetShapeToMesh(), SMESH_Mesh::GetShapeToMesh(), SMESH_Gen_i::getStudyServant(), SMESH_Mesh::GetSubMesh(), SMESH_Gen_i::GetSubMeshOnCompoundTag(), SMESH_Gen_i::GetSubMeshOnEdgeTag(), SMESH_Gen_i::GetSubMeshOnFaceTag(), SMESH_Gen_i::GetSubMeshOnShellTag(), SMESH_Gen_i::GetSubMeshOnSolidTag(), SMESH_Gen_i::GetSubMeshOnVertexTag(), SMESH_Gen_i::GetSubMeshOnWireTag(), SMESH_Gen_i::GetVolumeGroupsTag(), SMESH_Mesh_i::HasShapeToMesh(), SMESH_Mesh::HasShapeToMesh(), SMESH_Hypothesis_i::LoadFrom(), SMESH_PreMeshInfo::LoadFromFile(), SMESH_Mesh_i::MainShapeTick(), StudyContext::mapOldToNew(), MESSAGE, SMESH_Gen_i::myStudyContext, SMESH_Mesh::PseudoShape(), SMESH_Mesh::SetAutoColor(), SMESHDS_GroupBase::SetColor(), SMESH_Mesh::SetMeshOrder(), SMESHDS_Mesh::SetPersistentId(), SMESH_Mesh_i::SetShape(), SMESHDS_GroupBase::SetStoreName(), SMESH_Gen_i::SObjectToObject(), SMESH_GroupOnFilter_i::StringToFilter(), SMESH_subMesh::SUBMESH_RESTORED, SMESH_Hypothesis_i::UpdateAsMeshesRestored(), and SMESH_Gen_i::UpdateStudy().
Referenced by SMESH_Gen_i::LoadASCII().
◆ LoadASCII()
bool SMESH_Gen_i::LoadASCII ( SALOMEDS::SComponent_ptr  theComponent,
bool  isMultiFile
Load SMESH module's data in ASCII format
References SMESH_Gen_i::Load(), and MESSAGE.
◆ LocalPersistentIDToIOR()
char * SMESH_Gen_i::LocalPersistentIDToIOR ( SALOMEDS::SObject_ptr  theSObject,
const char *  aLocalPersistentID,
Transform data from persistent form to transient
References StudyContext::getIORbyOldId(), MESSAGE, and SMESH_Gen_i::myStudyContext.
◆ MakeGroupsOfBadInputElements()
SMESH::ListOfGroups * SMESH_Gen_i::MakeGroupsOfBadInputElements ( SMESH::SMESH_Mesh_ptr  theMesh,
const char *  theGroupName
◆ Move()
void SMESH_Gen_i::Move ( const SMESH::sobject_list &  what,
CORBA::Long  row
◆ ObjectToSObject()
SALOMEDS::SObject_ptr SMESH_Gen_i::ObjectToSObject ( CORBA::Object_ptr  theObject)
References SMESH_Gen_i::GetORB(), and SMESH_Gen_i::getStudyServant().
Referenced by SMESH_Mesh_i::addGeomGroupData(), SMESH_Gen_i::AddHypothesisToShape(), SMESH_Gen_i::addReference(), SMESH_Mesh_i::CheckGeomGroupModif(), SMESH_Mesh_i::CheckGeomModif(), SMESH_Mesh_i::checkGroupNames(), SMESH_Gen_i::ConcatenateCommon(), SMESH_Mesh_i::ConvertToStandalone(), SMESH_Gen_i::CopyMesh(), SMESH_Gen_i::CopyMeshWithGeom(), SMESH_Gen_i::CreateDualMesh(), SMESHGUI_MeshOp::createMesh(), SMESH_Mesh_i::ExportCGNS(), SMESH_Mesh_i::ExportPartToMEDCommon(), SMESH_Mesh_i::ExportPartToSTL(), SMESH_Mesh_i::ExportSTL(), SMESH_Mesh_i::ExportStructuredCGNS(), SMESH_Gen_i::FindGeometryByMeshElement(), SMESH_Mesh_i::generateMeshName(), SMESH_Gen_i::GetGeometryByMeshElement(), SMESH_Gen_i::GetMeshOrSubmeshByShape(), SMESH_Gen_i::GetParameters(), SMESH_Gen_i::HighLightInvalid(), SMESH_Mesh_i::ImportSTLFile(), SMESH_Gen_i::isGeomModifIcon(), SMESH_Hypothesis_i::IsPublished(), SMESH_MeshEditor_i::makeMesh(), SMESH_Mesh_i::newGroupShape(), SMESH_MeshEditor_i::Offset(), SMESH::TPythonDump::operator<<(), SMESH_Mesh_i::prepareMeshNameAndGroups(), SMESH_Gen_i::publish(), SMESH_Gen_i::PublishGroup(), SMESH_Gen_i::PublishHypothesis(), SMESH_Gen_i::PublishMesh(), SMESH_Gen_i::PublishSubMesh(), SMESH_Mesh_i::RemoveGroup(), SMESH_Gen_i::RemoveHypothesisFromShape(), SMESH_Mesh_i::RemoveSubMesh(), SMESH_Mesh_i::ReplaceShape(), SMESH_Gen_i::Save(), SMESH_GroupBase_i::SetName(), SMESH_Gen_i::SetName(), StdMeshers_ImportSource1D_i::SetSourceEdges(), StdMeshers_ImportSource2D_i::SetSourceFaces(), SMESH_Gen_i::UpdateGroupIcon(), SMESH_Gen_i::UpdateIcons(), and SMESH_Gen_i::UpdateParameters().
◆ PasteInto()
SALOMEDS::SObject_ptr SMESH_Gen_i::PasteInto ( const SALOMEDS::TMPFile &  ,
CORBA::Long  ,
◆ PausePythonDumpRecording()
void SMESH_Gen_i::PausePythonDumpRecording ( )
CORBA wrapper to increment TPythonDump suppression counter (myCounter). Called from Python plugins to pause the record of intermediate operations.
References SMESH::TPythonDump::IncrementMyCounter().
◆ Precompute()
◆ publish()
SALOMEDS::SObject_ptr SMESH_Gen_i::publish ( CORBA::Object_ptr  theIOR,
const int  theTag = 0,
const char *  thePixMap = 0,
const bool  theSelectable = true
◆ PublishComponent()
◆ PublishGroup()
◆ PublishHypothesis()
◆ PublishInStudy()
SALOMEDS::SObject_ptr SMESH_Gen_i::PublishInStudy ( SALOMEDS::SObject_ptr  theSObject,
◆ PublishMesh()
◆ PublishSubMesh()
◆ RegisterObject()
◆ ReloadMeshesFromCGNS()
◆ ReloadMeshesFromGMF()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::ReloadMeshesFromGMF ( const char *  theFileName,
◆ ReloadMeshesFromMED()
◆ ReloadMeshesFromMESHIO()
◆ ReloadMeshesFromSTL()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::ReloadMeshesFromSTL ( const char *  theFileName,
◆ ReloadMeshesFromUNV()
SMESH::SMESH_Mesh_ptr SMESH_Gen_i::ReloadMeshesFromUNV ( const char *  theFileName,
◆ ReloadMeshFromFile()
◆ RemoveHypothesisFromShape()
bool SMESH_Gen_i::RemoveHypothesisFromShape ( SMESH::SMESH_Mesh_ptr  theMesh,
◆ RemoveLastFromPythonScript()
void SMESH_Gen_i::RemoveLastFromPythonScript ( )
◆ ResumePythonDumpRecording()
void SMESH_Gen_i::ResumePythonDumpRecording ( )
CORBA wrapper to decrement TPythonDump suppression counter (myCounter). Called from Python plugins to resume normal dump recording.
References SMESH::TPythonDump::DecrementMyCounter().
◆ Save()
SALOMEDS::TMPFile * SMESH_Gen_i::Save ( SALOMEDS::SComponent_ptr  theComponent,
bool  isMultiFile
SMESH_Gen_i::Save.
Save SMESH module's data
References DriverMED_W_SMESHDS_Mesh::AddGroup(), SMDS_Mesh::elementsIterator(), SMESH_Mesh_i::FileInfoToString(), StudyContext::findId(), SMESH_Gen_i::Get0DElementsGroupsTag(), SMESH_Gen_i::GetAlgorithmsRootTag(), SMESH_Mesh_i::GetAutoColor(), SMESH_Gen_i::GetBallElementsGroupsTag(), SMESH_GroupBase_i::GetColor(), SMESH_Gen_i::GetEdgeGroupsTag(), SMESH_Gen_i::GetFaceGroupsTag(), SMESH_GroupBase_i::GetGroupDS(), SMESHDS_Mesh::GetHypothesis(), SMESH_Gen_i::GetHypothesisRootTag(), SMDS_MeshElement::GetID(), SMESHDS_GroupBase::GetID(), SMESHDS_SubMesh::GetID(), SMESH_Mesh_i::GetImpl(), SMESH_Mesh::GetIsModified(), SMESH_GroupBase_i::GetLocalID(), SMESH_Mesh::GetMeshDS(), SMDS_Mesh::GetMeshInfo(), SMESH_Mesh::GetMeshOrder(), SMESH_GroupBase_i::GetName(), SMESH_Hypothesis_i::GetName(), SMESH_Gen_i::GetNodeGroupsTag(), SMESHDS_SubMesh::GetNodes(), SMESH_Gen_i::GetORB(), SMESHDS_Mesh::GetPersistentId(), SMDS_MeshNode::GetPosition(), SMESH_Gen_i::GetRefOnAppliedAlgorithmsTag(), SMESH_Gen_i::GetRefOnAppliedHypothesisTag(), SMESH_Gen_i::GetRefOnShapeTag(), SMESH_Gen_i::GetServant(), SMESHDS_GroupBase::GetStoreName(), SMESH_Gen_i::getStudyServant(), SMESH_Gen_i::GetSubMeshOnCompoundTag(), SMESH_Gen_i::GetSubMeshOnEdgeTag(), SMESH_Gen_i::GetSubMeshOnFaceTag(), SMESH_Gen_i::GetSubMeshOnShellTag(), SMESH_Gen_i::GetSubMeshOnSolidTag(), SMESH_Gen_i::GetSubMeshOnVertexTag(), SMESH_Gen_i::GetSubMeshOnWireTag(), SMESH_Gen_i::GetVolumeGroupsTag(), SMESH_Mesh::HasShapeToMesh(), SMESHDS_Mesh::IndexToShape(), SMESHDS_SubMesh::IsComplexSubmesh(), SMESH_Mesh_i::MainShapeTick(), SMESHDS_Mesh::MaxShapeIndex(), SMESH_Gen_i::myStudyContext, SMDS_MeshInfo::NbElements(), SMDS_Mesh::NbNodes(), SMESHDS_SubMesh::NbNodes(), NUM_TMP_FILES, SMESH_Gen_i::ObjectToSObject(), DriverMED_W_SMESHDS_Mesh::Perform(), SMESH_Mesh::RemoveHypothesis(), SMESH_Gen_i::SavePython(), SMESH_Hypothesis_i::SaveTo(), SMESH_PreMeshInfo::SaveToFile(), DriverMED_W_SMESHDS_Mesh::SetFile(), Driver_SMESHDS_Mesh::SetMesh(), Driver_Mesh::SetMeshId(), SMESHDS_GroupBase::SetStoreName(), SMESH_Gen_i::ShapeToGeomObject(), SMESH_Mesh::ShapeToMesh(), SMESHDS_Mesh::ShapeToMesh(), SMDSAbs_All, SMDSAbs_Node, SMESH_Gen_i::SObjectToObject(), SMESHDS_Mesh::SubMeshes(), and SMESH_Gen_i::UpdateStudy().
Referenced by SMESH_Gen_i::SaveASCII().
◆ SaveASCII()
SALOMEDS::TMPFile * SMESH_Gen_i::SaveASCII ( SALOMEDS::SComponent_ptr  theComponent,
bool  isMultiFile
Save SMESH module's data in ASCII format
References MESSAGE, and SMESH_Gen_i::Save().
◆ SavePython()
◆ SetBoundaryBoxSegmentation()
void SMESH_Gen_i::SetBoundaryBoxSegmentation ( CORBA::Long  theNbSegments)
Set number of segments per diagonal of boundary box of geometry by which default segment length of appropriate 1D hypotheses is defined.
References SMESH_Gen_i::myGen, and SMESH_Gen::SetBoundaryBoxSegmentation().
◆ SetDefaultNbSegments()
void SMESH_Gen_i::SetDefaultNbSegments ( CORBA::Long  theNbSegments)
Set default number of segments per edge.
References SMESH_Gen_i::myGen, and SMESH_Gen::SetDefaultNbSegments().
◆ SetEmbeddedMode()
void SMESH_Gen_i::SetEmbeddedMode ( CORBA::Boolean  theMode)
◆ SetEnablePublish()
void SMESH_Gen_i::SetEnablePublish ( CORBA::Boolean  theIsEnablePublish)
◆ SetGeomEngine()
void SMESH_Gen_i::SetGeomEngine ( GEOM::GEOM_Gen_ptr  geomcompo)
Set GEOM::GEOM_Gen reference
◆ SetName() [1/2]
◆ SetName() [2/2]
void SMESH_Gen_i::SetName ( SALOMEDS::SObject_ptr  theSObject,
const char *  theName,
const char *  theDefaultName = 0
◆ SetNS()
void SMESH_Gen_i::SetNS ( SALOME_NamingService_Abstract *  ns)
◆ SetOption()
void SMESH_Gen_i::SetOption ( const char *  name,
const char *  value
◆ SetPixMap()
◆ ShapeToGeomObject()
◆ SObjectToObject()
◆ ToForgetMeshDataOnHypModif()
bool SMESH_Gen_i::ToForgetMeshDataOnHypModif ( ) const
◆ UpdateGroupIcon()
◆ UpdateIcons()
◆ UpdateParameters()
void SMESH_Gen_i::UpdateParameters ( CORBA::Object_ptr  theObject,
const char *  theParameters
[in]theObject- the object whose a method WILL be called with theParameters.
[in]theParameters- a string containing parameters separated by ':'.
References SMESH_Gen_i::getStudyServant(), SMESH_Gen_i::myLastObj, SMESH_Gen_i::myLastParameters, SMESH_Gen_i::myLastParamIndex, and SMESH_Gen_i::ObjectToSObject().
Referenced by SMESH_Mesh_i::SetParameters(), and SMESH::TPythonDump::~TPythonDump().
◆ UpdateStudy()
◆ myDefaultGroupColor
std::string SMESH_Gen_i::myDefaultGroupColor
privateinherited
◆ myGen
◆ myGeomGen
GEOM::GEOM_Gen_var SMESH_Gen_i::myGeomGen
staticprotectedinherited
◆ myHypCreatorMap
◆ myIsEmbeddedMode
◆ myIsEnablePublish
◆ myIsHistoricalPythonDump
bool SMESH_Gen_i::myIsHistoricalPythonDump
privateinherited
◆ myLastObj
std::string SMESH_Gen_i::myLastObj
privateinherited
◆ myLastParameters
std::vector< std::string > SMESH_Gen_i::myLastParameters
privateinherited
◆ myLastParamIndex
std::vector< int > SMESH_Gen_i::myLastParamIndex
privateinherited
◆ myLCC
SALOME_LifeCycleCORBA * SMESH_Gen_i::myLCC = nullptr
staticprivateinherited
Referenced by SMESH_Gen_i::GetLCC().
◆ myNS
SALOME_NamingService_Abstract * SMESH_Gen_i::myNS = nullptr
◆ myOrb
CORBA::ORB_var SMESH_Gen_i::myOrb
◆ myPoa
PortableServer::POA_var SMESH_Gen_i::myPoa
◆ myShapeReader
GEOM_Client* SMESH_Gen_i::myShapeReader
privateinherited
◆ mySMESHGen
◆ myStudyContext
◆ myToForgetMeshDataOnHypModif
bool SMESH_Gen_i::myToForgetMeshDataOnHypModif
privateinherited
