GeomAlgoAPI_Placement Class Reference
Creates the copied object which sub-element is placed on the given element. More...
#include <GeomAlgoAPI_Placement.h>
Inheritance diagram for GeomAlgoAPI_Placement:
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Placement (const std::shared_ptr< GeomAPI_Shape > theSourceSolid, const std::shared_ptr< GeomAPI_Shape > theDestSolid, const std::shared_ptr< GeomAPI_Shape > theSourceShape, const std::shared_ptr< GeomAPI_Shape > theDestShape, const bool theIsReverse=false, const bool theIsCentering=false, const bool theSimpleTransform=false)
 Creates an object which is obtained from current object by transformation calculated as a movement of the source object to be coincident with the destination object. More...
GEOMALGOAPI_EXPORT std::shared_ptr< GeomAPI_Trsf > transformation () const
 Returns the simple transformation. More...
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Placement()
GeomAlgoAPI_Placement::GeomAlgoAPI_Placement ( const std::shared_ptr< GeomAPI_Shape >  theSourceSolid,
const bool  theIsReverse = false,
const bool  theIsCentering = false,
const bool  theSimpleTransform = false
[in]theSourceSolida shape to be moved
[in]theDestSolidinvariant shape
[in]theSourceShapea shape on the solid to be made coincident with destination object
[in]theDestShapedestination object
[in]theIsReverseindicates that the solid materials should be on the same side against the destination plane
[in]theIsCenteringindicates the planes should be centered
[in]theSimpleTransformmakes just transformation of shape without changing of topology or geometry
◆ transformation()
std::shared_ptr< GeomAPI_Trsf > GeomAlgoAPI_Placement::transformation ( ) const
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modified()
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
