Creates a copy of the object by performing a scale operation by a factor or by dimensions. More...
#include <GeomAlgoAPI_Scale.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Scale (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Pnt > theCenterPoint, double theScaleFactor) |
| Creates an object which is obtained from current object by performing a scale operation by a factor. More... | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Scale (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Pnt > theCenterPoint, double theScaleFactorX, double theScaleFactorY, double theScaleFactorZ) |
| Creates an object which is obtained from current object by performing a scale operation by dimensions. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
| void | build (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Trsf > theTrsf) |
| Builds resulting shape. More... | |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_Scale::GeomAlgoAPI_Scale | ( | std::shared_ptr< GeomAPI_Shape > | theSourceShape, |
| std::shared_ptr< GeomAPI_Pnt > | theCenterPoint, | ||
| double | theScaleFactor | ||
| [in] | theSourceShape | the shape to be moved. |
| [in] | theCenterPoint | the center point. |
| [in] | theFactor | the scale factor. |
| double | theScaleFactorX, | ||
| double | theScaleFactorY, | ||
| double | theScaleFactorZ | ||
| [in] | theFactorX | the scale factor in X. |
| [in] | theFactorY | the scale factor in Y. |
| [in] | theFactorZ | the scale factor in Z. |
protectedinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
inlineinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
