GeomAlgoAPI_SketchBuilder Class Reference
Creates planar faces based on the list of Sketch features. More...
#include <GeomAlgoAPI_SketchBuilder.h>
Inheritance diagram for GeomAlgoAPI_SketchBuilder:
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_SketchBuilder (const std::shared_ptr< GeomAPI_Pln > &thePlane, const std::list< std::shared_ptr< GeomAPI_Shape > > &theEdges)
 Creates list of faces based on the edges of the sketch. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_SketchBuilder (const std::shared_ptr< GeomAPI_Pnt > &theOrigin, const std::shared_ptr< GeomAPI_Dir > &theDirX, const std::shared_ptr< GeomAPI_Dir > &theNorm, const std::shared_ptr< GeomAPI_Shape > &theWire)
 Creates list of faces and unclosed wires on basis of the features of the sketch. More...
GEOMALGOAPI_EXPORT const std::list< std::shared_ptr< GeomAPI_Shape > > & faces () const
 Return list of created faces. More...
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_SketchBuilder() [1/2]
GeomAlgoAPI_SketchBuilder::GeomAlgoAPI_SketchBuilder ( const std::shared_ptr< GeomAPI_Pln > &  thePlane,
const std::list< std::shared_ptr< GeomAPI_Shape > > &  theEdges
[in]thePlaneplane of the sketch
[in]theEdgesinitial edges of the sketch
The algorithm searches all loops of edges surrounding lesser areas.
◆ GeomAlgoAPI_SketchBuilder() [2/2]
GeomAlgoAPI_SketchBuilder::GeomAlgoAPI_SketchBuilder ( const std::shared_ptr< GeomAPI_Pnt > &  theOrigin,
const std::shared_ptr< GeomAPI_Dir > &  theDirX,
const std::shared_ptr< GeomAPI_Dir > &  theNorm,
const std::shared_ptr< GeomAPI_Shape > &  theWire
[in]theOriginorigin point of the sketch
[in]theDirXx-direction of the sketch
[in]theNormnormal of the sketch
[in]theWirea wire which contains all edges
◆ faces()
GEOMALGOAPI_EXPORT const std::list< std::shared_ptr< GeomAPI_Shape > > & GeomAlgoAPI_SketchBuilder::faces ( ) const
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modified()
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
