YACS::HMI::VisitorSaveGuiSchema Class Reference
#include <VisitorSaveGuiSchema.hxx>
Inheritance diagram for YACS::HMI::VisitorSaveGuiSchema:
Collaboration diagram for YACS::HMI::VisitorSaveGuiSchema:
 VisitorSaveGuiSchema (YACS::ENGINE::Proc *proc)
virtual ~VisitorSaveGuiSchema ()
virtual void visitProc ()
- Public Member Functions inherited from YACS::ENGINE::VisitorSaveSalomeSchema
 VisitorSaveSalomeSchema (ComposedNode *root)
virtual ~VisitorSaveSalomeSchema ()
virtual void visitPresetNode (DataNode *node)
virtual void visitOutNode (DataNode *node)
virtual void visitStudyInNode (DataNode *node)
virtual void visitStudyOutNode (DataNode *node)
- Public Member Functions inherited from YACS::ENGINE::VisitorSaveSchema
 VisitorSaveSchema (ComposedNode *root)
virtual ~VisitorSaveSchema ()
void openFileSchema (std::string xmlDump)
void closeFileSchema ()
virtual void visitBloc (Bloc *node)
virtual void visitElementaryNode (ElementaryNode *node)
void visitForEachLoop (ForEachLoop *node) override
void visitForEachLoopDyn (ForEachLoopDyn *node) override
virtual void visitOptimizerLoop (OptimizerLoop *node)
virtual void visitDynParaLoop (DynParaLoop *node)
virtual void visitForLoop (ForLoop *node)
virtual void visitInlineNode (InlineNode *node)
virtual void visitInlineFuncNode (InlineFuncNode *node)
virtual void visitLoop (Loop *node)
virtual void visitProc (Proc *node)
virtual void visitServiceNode (ServiceNode *node)
virtual void visitServerNode (ServerNode *node)
virtual void visitServiceInlineNode (ServiceInlineNode *node)
virtual void visitSwitch (Switch *node)
virtual void visitWhileLoop (WhileLoop *node)
 Visitor (ComposedNode *root)
virtual void visitBloc (Bloc *node)=0
virtual void visitElementaryNode (ElementaryNode *node)=0
virtual void visitForEachLoop (ForEachLoop *node)=0
virtual void visitForEachLoopDyn (ForEachLoopDyn *node)=0
virtual void visitOptimizerLoop (OptimizerLoop *node)=0
virtual void visitDynParaLoop (DynParaLoop *node)=0
virtual void visitForLoop (ForLoop *node)=0
virtual void visitInlineNode (InlineNode *node)=0
virtual void visitInlineFuncNode (InlineFuncNode *node)=0
virtual void visitLoop (Loop *node)=0
virtual void visitProc (Proc *node)=0
virtual void visitServiceNode (ServiceNode *node)=0
virtual void visitServerNode (ServerNode *node)=0
virtual void visitServiceInlineNode (ServiceInlineNode *node)=0
virtual void visitSwitch (Switch *node)=0
virtual void visitWhileLoop (WhileLoop *node)=0
virtual void visitPresetNode (DataNode *node)=0
virtual void visitOutNode (DataNode *node)=0
virtual void visitStudyInNode (DataNode *node)=0
virtual void visitStudyOutNode (DataNode *node)=0
virtual void writePresentation ()
virtual void writeItem (std::string name, SceneNodeItem *item)
- Protected Member Functions inherited from YACS::ENGINE::VisitorSaveSalomeSchema
virtual void writeDataNodeParameters (DataNode *node)
virtual void writeStudyInNodeParameters (DataNode *node)
virtual void writeOutNodeParameters (DataNode *node)
virtual void writeStudyOutNodeParameters (DataNode *node)
- Protected Member Functions inherited from YACS::ENGINE::VisitorSaveSchema
virtual void writeProperties (Node *node)
virtual void dumpTypeCode (TypeCode *type, std::set< std::string > &typeNames, std::map< std::string, TypeCode * > &typeMap, int depth)
virtual void writeTypeCodes (Proc *proc)
virtual void writeContainers (Proc *proc)
virtual void writeComponentInstances (Proc *proc)
virtual void writeInputPorts (Node *node)
virtual void writeInputDataStreamPorts (Node *node)
virtual void writeOutputPorts (Node *node)
virtual void writeOutputDataStreamPorts (Node *node)
virtual void writeControls (ComposedNode *node)
virtual void writeSimpleDataLinks (ComposedNode *node)
virtual void writeSimpleStreamLinks (ComposedNode *node)
virtual void writeParameters (Proc *proc)
virtual void writeParametersNode (ComposedNode *proc, Node *node)
virtual void beginCase (Node *node)
virtual void endCase (Node *node)
std::set< Node * > getAllNodes (ComposedNode *node)
int depthNode (Node *node)
std::string indent (int val)
std::map< std::string, std::string > getNodeProperties (Node *node)
std::map< std::string, TypeCode * > getTypeCodeMap (Proc *proc)
std::map< std::string, Container * > getContainerMap (Proc *proc)
std::list< TypeCodeObjref * > getListOfBases (TypeCodeObjref *objref)
YACS::ENGINE::Proc * _proc
- Protected Attributes inherited from YACS::ENGINE::VisitorSaveSchema
std::ofstream _out
std::map< int, std::string > _nodeStateName
std::map< std::string, Container * > _containerMap
std::map< ComponentInstance *, std::string > _componentInstanceMap
ComposedNode * _root
std::multimap< int, DataLinkInfo > _mapOfDLtoCreate
std::multimap< int, StreamLinkInfo > _mapOfSLtoCreate
Definition at line 39 of file VisitorSaveGuiSchema.hxx.
◆ VisitorSaveGuiSchema()
VisitorSaveGuiSchema::VisitorSaveGuiSchema ( YACS::ENGINE::Proc *  proc)
Definition at line 36 of file VisitorSaveGuiSchema.cxx.
37 : VisitorSaveSalomeSchema(proc), _proc(proc)
38{
39 DEBTRACE("VisitorSaveGuiSchema::VisitorSaveGuiSchema");
40}
References DEBTRACE.
◆ ~VisitorSaveGuiSchema()
VisitorSaveGuiSchema::~VisitorSaveGuiSchema ( )
Definition at line 42 of file VisitorSaveGuiSchema.cxx.
43{
44 DEBTRACE("VisitorSaveGuiSchema::~VisitorSaveGuiSchema");
45}
◆ visitProc()
void VisitorSaveGuiSchema::visitProc ( )
Definition at line 47 of file VisitorSaveGuiSchema.cxx.
48{
49 DEBTRACE("VisitorSaveGuiSchema::visitProc");
50 VisitorSaveSalomeSchema::visitProc(_proc);
52}
References _proc, DEBTRACE, and writePresentation().
Referenced by YACS::HMI::GenericGui::onExportSchema(), YACS::HMI::GenericGui::onExportSchemaAs(), and YACS::HMI::GenericGui::onRunLoadedSchema().
◆ writeItem()
void VisitorSaveGuiSchema::writeItem ( std::string  name,
SceneNodeItem *  item
Definition at line 78 of file VisitorSaveGuiSchema.cxx.
79{
80 int depth = 1;
81 _out << indent(depth) << "<presentation";
82 _out << " name=\"" << name << "\"";
83 _out << " x=\"" << item->x() << "\"";
84 _out << " y=\"" << item->y() << "\"";
85 _out << " width=\"" << item->getWidth() << "\"";
86 _out << " height=\"" << item->getHeight() << "\"";
87 _out << " expanded=\"" << item->isExpanded() << "\"";
88 _out << " expx=\"" << item->getExpandedX() << "\"";
89 _out << " expy=\"" << item->getExpandedY() << "\"";
90 _out << " expWidth=\"" << item->getExpandedWidth() << "\"";
91 _out << " expHeight=\"" << item->getExpandedHeight() << "\"";
92 _out << " shownState=\"" << item->getShownState() << "\"";
93 _out << "/>" << endl;
94}
References YACS::ENGINE::VisitorSaveSchema::_out, YACS::HMI::SceneNodeItem::getExpandedHeight(), YACS::HMI::SceneNodeItem::getExpandedWidth(), YACS::HMI::SceneNodeItem::getExpandedX(), YACS::HMI::SceneNodeItem::getExpandedY(), YACS::HMI::AbstractSceneItem::getHeight(), YACS::HMI::SceneNodeItem::getShownState(), YACS::HMI::AbstractSceneItem::getWidth(), YACS::ENGINE::VisitorSaveSchema::indent(), and YACS::HMI::SceneNodeItem::isExpanded().
Referenced by writePresentation().
◆ writePresentation()
void VisitorSaveGuiSchema::writePresentation ( )
Definition at line 54 of file VisitorSaveGuiSchema.cxx.
55{
56 DEBTRACE("VisitorSaveGuiSchema::writePresentation");
57 set<Node*> nodeSet = getAllNodes(_proc);
58
59 for (set<Node*>::iterator iter = nodeSet.begin(); iter != nodeSet.end(); ++iter)
60 {
61 Node* node = *iter;
64 YASSERT(item);
65 SceneNodeItem* inode = dynamic_cast<SceneNodeItem*>(item);
66 YASSERT(inode);
67 writeItem(_proc->getChildName(node), inode);
68 }
69
72 YASSERT(item);
73 SceneNodeItem* inode = dynamic_cast<SceneNodeItem*>(item);
74 YASSERT(inode);
75 writeItem("__ROOT__", inode);
76}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Base class for all nodes.
Definition: Node.hxx:70
std::set< Node * > getAllNodes(ComposedNode *node)
Definition: guiContext.hxx:70
YACS::HMI::SubjectProc * getSubjectProc()
Definition: guiContext.hxx:52
std::map< YACS::HMI::Subject *, YACS::HMI::SceneItem * > _mapOfSceneItem
virtual void writeItem(std::string name, SceneNodeItem *item)
References YACS::HMI::QtGuiContext::_mapOfSceneItem, YACS::HMI::GuiContext::_mapOfSubjectNode, _proc, DEBTRACE, YACS::ENGINE::VisitorSaveSchema::getAllNodes(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::GuiContext::getSubjectProc(), writeItem(), and YASSERT.
Referenced by visitProc().
◆ _proc
YACS::ENGINE::Proc* YACS::HMI::VisitorSaveGuiSchema::_proc
Definition at line 50 of file VisitorSaveGuiSchema.hxx.
Referenced by visitProc(), and writePresentation().
